How to Land a Plane
Introduction: How to Land a Plane
Don't Panic and follow this guide and you will be touching ground in no time.
I will show you the buttons to push and the levers to pull on two different aircrafts while the ground support lead you down.
Step 1: Call for Help.
This part is scary, both the pilots are knocked out and no one knows how to land this plane, but you as smart as you were read this instructable which makes you the last hope of the fifty some people aboard.
Make your way to the cockpit and calm down. Take the chair on the left because you are the captain now. Put on your headset which may still be on the knocked out pilot and switch on the radio. Tune it to 121.5 which is the emergency channel and push the talk button on the yoke to contact air control traffic. They will then call an instructor to guide you down so you live.
Step 2: Set the Autopilot.
Get the navigation aids from air traffic control and input them on this keyboard.
Step 3: Program Your Approach.
The instructor talking to you over the headset will give you a frequency, which you enter into the "Instrument Landing System". The device will then pick up radio signals from the assigned runaway and provide both lateral and vertical guidance, which means calculate the exact speed and angle of your decent which tends to be 3 degrees.
Step 4: Prepare for Landing.
Keep an eye on your speed. When it falls to 130 knots, flip the switch to lower the flaps, then pull the lever to release the landing gear.
Step 5: Brake Carefully.
If you are breaking when you land, the tires will blow instantly. Once you touch down, push the tops of the pedals, whereas the bottoms are for steering. Feel accomplished, you have just saved the lives of many from plummeting into the ocean or whatever you were over.
    • Pocket-Sized Contest
    • Science of Cooking
      Science of Cooking
    • Pro Tips Challenge
      Pro Tips Challenge
    This is rubbish you don't even explain how to change the frequency
    DAMN! You beat me to it... That said this is good for someone that knows something already but you look at the switches in even a small single prop, they have to figure out what's what... and fast...
    I thought for sure you would make about making your own for dummies like me who don't know an led from their elbow?
    Umm you could be scuppered... This one does cover the basics, the thing it's missing is not a where the controls are because it varies widely but to ask the control tower where each bit is... If my dad was still around he could have written how to land a plane in a field, how to jump a deer that want's a fight on the runway and how to shoot 30ft of flames from your turbo props exhausts...
    I read somewhere (wikihow, I think) that you should set the transponder to 7700 mhz, set the PTT radio headset to 121.50 and call mayday three times. And don't go touching a bunch of things, in case the autopilot is on and you mess it up.
    its known as SQUAWK 7700...actually, in any emergency there is special transponder codes that will always show highest priority on ATC's radar these are:
    1200: Visual Flight Rules
    7500: Highjack
    7600: Lost Comm. (No Radio)
    7700: which is a general "emergency" code that covers everything.
    when calling in a mayday it is always wise to include your flight info to ATC and you dont necessarilly have to dial in 121.50 just put the headset on push the PTT switch on the yoke and say something like this:
    MAYDAY MAYDAY MAYDAY This is American Flight 4390 from Chicago to Tulsa!!
    they will reply to you quicker than 9-1-1 and will give you full priority over all other aircraft. Just follow all commands from the tower (as they say lol).
    The first thing should always be radioing in... also an untrained co-pilot or even a steward may know since they will have been in the cabin when the pilot was previously flying capable... In the middle of a flight the autopilot will almost definitely be on for fuel reasons, radioing in is important because it notifies the right people. Also in many cases I'd rather not have an untrained pilot land on a runway, which are made to be just enough to do, something like a dry lake bed or beach seems much safer to me... Anywhere bigger is better...
    you can what if all you would like, but you wont always be around a runway, or a lake bed, or a land where you can save the most lives, and save the plane from the most damage possible.
    the autopilot will not be on for "fuel reasons" but because the Federal Aviation Regulations say they have to be (in an airliner) because of how high the airplane is above the ground. there is no such thing as an "untrained co-pilot" both pilots have the same level of training for that type of aircraft and the equipment on it, and the only thing that dictates their position is seniority.
    You should always land on the runway, thats what it was built for and it will hold as long as you don't land on the blast pad or displaced threshold, and the next best choice if you don't know what your doing would be to land on a straight stretch of highway (if you declare an emergency, the world is yours to land on). The planes landing gear would sink into a beach's sand.....if it was a small plane it would most likely flip over, and you'd probably die; and if it was a big plane then the landing gear would snap. On a dry lake bed there is no tower to watch and guide you in and now close medical support if something goes wrong.
    My point was more about having the distance, though in a completely screwed situation a beach is fine for a small plane, my dad did it, during an emergency. Also happened in a field, the wee old woman came out and offered him some soda bread and a brew... I think in the case of an emergency and they knew where you were going the lake bed wouldn't be the worst since there'd be little to hit and lots of space. A highway would work if it was wide and not elevated, I can imagine that making a mess... Exactly my point about radioing, declare an emergency...
