How-to: Laser Engraving Photo
Introduction: How-to: Laser Engraving Photo
I want to tell you how we engrave photos on a laser machine. After various tests, trial and error, born algorithm that allows you to get good quality engraving.
Step 1: Excellent Quality Photo
Use photo only excellent quality.
Open in Adobe Photoshop.
Step 2: Crop Photo
Crop photo as you need. Crop Tool (C)
Step 3: Remove Background
Carefully remove background.
Use Polygonal Lasso Tool (L) Feather 0px, Anti-alias.
Make a white background, merge layers (Ctrl+E)
Step 4: Convert Photo to Grayscale
Image > Mode > Grayscale
Step 5: Edit Photo
Large dark areas of photos light.
The intensity of black color on face should be 10-15%.
The eyes should be almost white. Black 3-6%.
Light hair strands create more light. Dodge Tool (O) Range: Highlights.
Dark hair strands darken. Burn Tool (O) Range: Shadows.
Step 6: Image Size
Resolution: 200 pixels/cm (508 pixels/inch)
Step 7: Sharpen
Filter > Sharpen > Unsharp Mask
Amount: 200 % Radius: 1 pixels Threshold: 0 levels.
Make sharper eye, eyelashes, eyebrows, lips, hair using Sharpen Tool.
Step 8: Convert Image to Bitmap
Image > Mode > Bitmap
Output: 200 pixels/cm (508 pixels/inch)
Method: Halftone Screen Frequency: 200 lines/cm (508 lines/inch)
Angle: 15 degrees
Shape: Round
Save As Format: BMP File
Format: Windows
Depth: 1 Bit
Step 9: Eye
Cut a piece of image for tests.
Eye - the best choice
Step 10: Laser Program
Import BMP image to RDWorks (or other your laser program).
Wood fibers should be parallel to the long axis (X).
Image as well.
Rotate image 90 degrees if necessary.
Set parameters for engrave
Parameters for 40 watt power laser (Program: RDCAM)
Speed(mm/s): 300 Max
Power(%): 20
Interval(mm): 0.05
Material: solid birch, plywood birch
Speed and power must be chosen by experimentation.
Step 11: Video
We use plywood birch in main.
It is accessible and cheap material.
Sand the plywood and cover it with varnish.
After engraving, wipe product with damp sponge to remove the soot and dust.
Step 12: Result
Good luck!
More designs for laser cutting and engraving:
    • Paper Contest 2018
      Paper Contest 2018
    • Pocket-Sized Contest
    • Science of Cooking
      Science of Cooking
    2 Questions
    I want to laser engrave a high res photo of animals on to the backs of cell phone cases. The backs are composed of cherry wood. The space on the cherry would I have to work with is about 2 x 3 inches. Any suggestions as to how to get a quality engraving? 30 watt epilog laser engraver. Corel Draw. I am attaching photos of a few tests. Thanks for any advice. I get my photos from Shutterstock and Depositphotos.
    which specific tool may we can use in Photoshop to complete the entire editing process?
    Check the easy tool here ( ) for preparing your photos for laser engraving. No need for any software. It takes 10 sec to covert a photo to pure black and white, and you are ready.
    I am completely new to engraving on a laser, had the machine less than a week and I want to do photo engraving but I am getting no detail at all. I am told my resolution is too low, anyone know of any videos that show me how to change resolution?
    I do a lot of engraving on acrylic on a Trotec Speedy 300,and I use a different method. I don't even bother taking out the backgrounds(personal choice). My first step it to convert to grayscale,then I go 300 for the resolution,then I go to adjustments>brightness/contrast and usually make both of those 25,but this can change depending on the picture.
    Next I go filter>sharpen>unsharp mask. I usually go amount-500%, radius-3,and keep threshold at 0.
    I don't even convert to bitmap,I just save it as one. The laser settings are definitely going to depend on your laser,and from what I understand,that goes for each individual laser even if they are the exact same model.
    I'll have to get some wood and try out your settings. Thanks.
    Of course, everything is individual. I found the best way for myself, which gives an excellent result.
    Wood luck!)
    Every now and then great results are obtained against all odds. This laser
    processed picture was scanned at 1200 dpi from a wallet sized faded photo, cropped, blown-up 15X and processed on cheap Big Box Store plywood. It has been my
    experience that none of those variables are recommended procedures. This is proof that accidents do
    So what program are you using? CorelPaint, Photoshop, ...?
    Hi Ed,
    I prepare photo in Photoshop only.
