How to Learn Small Sculptural Carving
13,105
110
13
Published
Introduction: How to Learn Small Sculptural Carving
About: I have been working with wood since I could stumble into the shop with my dad. About a year ago I moved into a house with no space for a full shop so I decided to take up all hand tool wood working. That sta...
Every year I try to stretch myself in my woodworking skills to make something new for my wife for Valentine's day. this year I decided to dabble in sculptural carving. For the full build video https://www.youtube.com/watch?v=I-U-AMbS-cE
Tools Needed
Carving Chisel Set: http://amzn.to/2kf8Wjb
Dovetail Saw: http://www.highlandwoodworking.com/veritas-doveta...
Bench Chisel Set: http://amzn.to/2i26mzX
Long-nosed marker: http://amzn.to/2lExV1e
Coping saw: http://amzn.to/2kCe68X
Carving Knife: http://amzn.to/2kNqwvI
Supplies Needed
Basswood used: http://amzn.to/2kBypUe
Boiled Linseed Oil: http://amzn.to/2hPEUVO
Step 1: Draw Out Pattern
I found a picture of what I wanted to try to make online and printed it out. Next, I freehand drew out what I wanted with a pencil untell I got the shape the way I wanted it. then I finalized the shape with a sharpie.
Step 2: Remove Most of the Waste
I start with a saw to cut in curfs at the low and high points along the sculpture. These are stop cuts so the majority of the wood can be removed with a large chisel. I come in with the bevel of the chisel down and slowly remove large portions of the in wanted wood tell I get close to the line. always keeping in mind the grain direction so you do not take off more than you want to.
Step 3: Remove Waste on Faces
Next, I repeat this on the front and back. On this side, I used a large gauge to quickly bring it down close to the shape in my mind. Do not worry about perfection.just have fun and be willing to learn and try new things.
Step 4: Shape the Main Body
At this point, it is all about experimenting. Try different chisels and see if they give you what you are looking for. always remember to make a stop cut and the remove the waste down to that stop cut. A bent neck is great for getting down into spaces that are hard to reach. Also at this point, the grain direction becomes very important. Cut across the grain, not into it. Just slowly chip away at it untell you get close to what you like.
Step 5: Shape Base
For the base, I could have done something fancy but I decided to keep it simple with a heavy smooth chamfer. Just using a straight chisel works fantastically on this basswood. feel free to experiment. Remember, your wife will love it because you spent the time to make it for her, not because it is perfect.
Step 6: Work on the Delicate Parts
For the heads, they were too delicate to use a chisel to remove the waste between them. For this, I found a coping saw was perfect. then it is more of the same. Using a gouge to remove the majority of the material, then, flip it over bevel up and use it to round the surfaces. For the space between the two bodies, I found a carving knife to make quick work of it. again do not be afraid to try something new and experiment.
Step 7: Final Surface
Initially, I was going yo give it a smooth surface and sand it, but I decided to leave it fairly rough. I like the aesthetic of the chipped surface. if you do decide to sand make sure it is the last thing to touch the wood. Any embedded sand will dull the tools. I also decided to use the V-Tool to put in a grove on the front of both bodies. it was a last minute idea that I am glad I added.
Step 8: FINNISH IT!
For a finish, I just used Boiled Linseed oil. the basswood soaked it up fast and I ended up putting on 4 coats with about 15 minutes between till the wood stopped soaking it up. I let it sit overnight, and sure enough, she likes it! be willing to have fun and try new things. you might be suprised.
Valentine's Day Challenge 2017
Runner Up in the
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    • Oil Contest
      Oil Contest
    13 Comments
    Nice simple instructions with tips!
    This is a really good guide! What is the thing you made? I looks pretty good, but I was wondering what it is.
    It is just an artistic sculpture to give my wife for Valentine's day. love the k-nex logo. a lot of years spent with those.
    I like it! It would probably take lots of work to make that shape, because carving the middle looks hard.
    it is not that hard. you just need to take it step by step.
    That's really sweet! Awesome Valentines' Day present :)
    thanks! This was a fun one. and she loves it. So that is what matters.
