How to Lifecast a Hand With Alginate
Introduction: How to Lifecast a Hand With Alginate
Lifecasting is making a mold of a living body. In this Instructable I make a wax casting of my hand. The overall result was impressive. The detail captured was better than I expected, with the texture of the skin being realistically captured.
Step 1: Materials and Tools
You will need the following materials and tools:
  • Alginate (I used dental grade)
  • Cold Water
  • Container (I used 2L pop bottle)
  • Stir Stick
  • Drill and Mixing Auger (optional but recommended)
  • Casting Material: wax, plaster, concrete, etc..
Step 2: Alginate
What makes this whole process possible is something called alginate. It is commonly used in the dental industry to make impressions of teeth. Try to get the slowest setting alginate as my first attempt I had a batch that was quick setting and I was not able to mix it with water quick enough and I ended up with a poor cast. I purchased mine from the local dental supply but you can find it online at various places like Amazon.
Step 3: Mix and Set
I did film the whole process so you can view it to see how it was done. I will try to document the written steps as well.
Follow the instructions for the alginate as each type can be different. For the type I am using, it is 1 litre of water per pound. I am using a drill and mixer to quickly mix the alginate. The colder the water the slower the alginate will set. If you are doing a large casting like I am, you want it to set slow. The stuff sets fast once mixed with water! I don't have any pics of the mixing but all I did was pour the alginate powder into the water and mix.
I mixed in a separate bucket and then poured into a 2 litre pop bottle that was a good size for my hand.
Step 4: Making the Impression
I put my hand in the mixed alginate and tried to keep it from the sides of the bottle. The alginate I am using takes about 2 minutes to set so I had to work really fast. Keep your hand still until the alginate sets to a rubbery texture.
You can now remove your hand, it took some wiggling of the fingers but eventually my hand came free. it might seem like it won't come out but take your time and it will. Don't be too rough or you will tear the alginate.
Step 5: Pouring the Mold
Get your casting material ready, I am using wax but you can use liquid stone, plaster, concrete etc...
I melted some tea lights for the wax and poured it into the alginate mold. I poured the wax into the mold then poured it out to establish a coating then filled the mold with wax and left it to cool. It will take a few hours with hot wax.
Step 6: Remove Alginate From Casting
Once your object is set, in my case the wax was hardened. I then started removing the alginate, slowly and carefully, since the fingers of my casting could easily be broken. I used a utility knife to score and then peel the alginate. It took some time but I managed to get it out with out any damage. For the really stuck alginate in the creases of the hand, I used a mixture of baking soda and water (1/4 cup per litre water) and let the hand soak for a few hours. Then I used a toothbrush to scrub at the creases.
Step 7: The Finished Wax Hand
The detailing captured by the alginate and wax of the hand is impressive. This would make a cool decorative object. Eventually I plan on using this positive wax hand and make a mold for lost wax casting.
    • Trash to Treasure
      Trash to Treasure
    • Paper Contest 2018
      Paper Contest 2018
    • Science of Cooking
      Science of Cooking
    If only I could send the cast hands to a glove factory, I'd be the happiest man alive. No surgical or industrial glove fits my extraterrestrialesque hands. :(
    Wonderful instructable!
    Dip the wax hand into some latex and let it dry, then peel off your perfect fitting latex gloves.
    hi great tutorial , I'm going to try it soon ,may I ask , is it okay if I use liquid wax bought instead of melting the candles , there's is no difference for the final cast , right ?
    Great Instructable and the vid is a bonus. The creamier you can get the alginate, the better. That's done by mixing it more and/or adding a little more water. Always a challenge as you can quickly run out of time. Use an air nozzle (using small puffs) to help separate the alginate from your final model as it will make a small gap of air to get rid of the suction when you try to remove your final cast. Do NOT use compressed air to separate your hand from the alginate as you run the risk of injury.
    Your correct about not using compressed air to separate your hand. I was told as an apprentice compressed air can get into any break of skin and cause an embolism straight to your heart and brain. A very slow and painfull way to die.
    For clarification. Is it okay to use air from an air compressor, don't use compressed air from a can?
    as the saying goes "compressed air " in other words air contained under extreme pressure held in a suitable container that can bear the strain/stress of the compressed gas held within it.
    On the subject of compressors the tank itself should be checked out yearly by ultrasound ,this is to check the thickness of the wall of the tank which gets thinner over time by internal corrosion. Failure to do this can make your insurance invalid if the tank did explode and harm somebody . Unlikely I admit, unless you have an old machine, but insurance companies will look for a way not to pay out for any damage or otherwise.
    No compressed air of any form is considered a risk.
    Personally haven't done research and can't really believe it, but I've heard quite a few people say that.
    You just need a few puffs to blow between your final cast and alginate. Whatever you got will probably work.
    Fascinating. Wonderful job. Wonderful video to accompany your instructable. You make it seem easy, although it is challenging to get it done correctly and cleaned up without messing up your hard work. Good luck on your next steps.
