3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Listen to Light
The human eye cannot discern flicker with a frequency greater than roughly 30 Hz. A light turning on and off faster than this does not appear to be turning on and off. Instead it appears to have a constant intensity to the eye.
Human ears however are much faster, that is, better able to perceive a signal changing quickly in time. The human ear can detect frequencies from roughly 20 Hz to 20 000 Hz, provided those frequencies arrive as sound.
Now suppose there were an easy way to change light of time-varying intensity, into sound of time varying intensity. Then you could "hear" light that was flickering too fast for you to see it.
The humble silicon solar-cell can convert a time-varying light signal into a time-varying electrical signal. This small electrical signal can then be fed to an audio signal amplifier and converted into sound.
Step 1Parts:
Parts:
1 audio amplifier (Radio Shack Catalog #:277-1008)
1 1/8-inch (3mm) headphone plug, can be mono or stereo
1 small Silicon solar cell with approximately 1 cm2 in area
1 1/2-inch PVC pipe cap
some wire, solder, epoxy, black paint, etc.
38 comments
Sep 22, 2011. 1:52 PMblinkyblinky says:
(removed by author or community request)
Oct 23, 2011. 3:24 PMRobot Lover says:
Actually this guy posted his about 3 years prior to your ible'
Oct 23, 2011. 4:40 PMblinkyblinky says:
WHAT DID YOU SAY???
Just Kidding...but mine uses headphone:)-
Oct 17, 2011. 5:20 PMdrbill says:
Would be Very Interesting to listen to Modulated Laser Light.
Maybe even have 2 way line-of-sight laser communication.
Sep 22, 2011. 1:50 PMblinkyblinky says:
Thanks...I had really wanted to record the sound my light listener made but had no time...
Sep 22, 2011. 11:50 PMblinkyblinky says:
You're welcome...but...THIS IS EXACTLY MY CONCEPT!!!!
May 16, 2008. 7:04 PMGeoffrito says:
whoa, that's interesting. Who'd have thought that candles secretly play music?
Nov 13, 2010. 11:12 AMDIY-Guy says:
Now people can sell battery powered tea light candles for privacy concerns, to help confuse laser window monitoring bugging equipment!
Although it won't work well against the good optical bugs because a technician will just tune out the frequency of the tone generated tea light music.
Can I get an LED that plays the theme from "Get Smart" please?
Dunt da daaa DA!
Dunt da daaa Duh!
Nov 7, 2010. 8:20 AMKlaudiuszm says:
I made one of these with a broken solar light. I figured it would have a nice enclosure and well, it was the only panel I had in my house.
Nov 11, 2010. 11:09 AMKlaudiuszm says:
Yeah I have. remotes are always fun. plus my glade air freshener light. I had also built a http://www.instructables.com/id/Music-LED-Light-Box/. I found that you can attach it for some visible fun. :D
Oct 21, 2010. 8:39 AMrcisneros says:
Actually you are half right.
They are prob using the music chip as a template that produces a smooth flicker cycle they have tons of.
The second part is because our brains naturally like certain sounds, patterns and tones. We change them over time, but there is a larger portion of these tones and patterns in classical music. I believe Bach is the winner in that category.
In that way flicker would cycle would be more pleasing.
Mar 23, 2010. 7:37 AMtheGpayne says:
hey, would it be possible to use a solar panel from a calculator? would i just hook up the cables on that directly to the 3mm plug?
May 27, 2008. 6:38 AMLoolykinns says:
dont you have any live sample of the output? I'd love to hear whats the output
May 17, 2008. 7:53 AMKiteman says:
Flickering LED "candles" also often play "Happy Birthday", even at Christmas. The mass-produced chips from musical cards are stupidly cheap when bought in factory-scale bulk.
Somewhere (SciToys?) I have seen this idea as half a laser-communicator. A microphone is used to add a flicker to a laser pointer's beam, which is focussed on a distant solar-cell, and an amplifier is used to turn the flickering output back into sound. Not hi-fi, but cool.
It would also be cool if you could post some mp3 or wav files of different sounds you have produced - what does that version of Fur Elise sound like? How annoying can a strip-light be?
Jul 25, 2009. 10:15 PMUnit042 says:
Yes, I first saw it on scitoys too. Sound amplitude modulated laser light. (Intensity of light followed that of the sound source's wave)
Jul 25, 2009. 10:16 PMUnit042 says:
Um, "it" as in, the laser communicator.
May 24, 2008. 7:45 AMthewoodcarver says:
Very nice job Jack maybe add a mp3 ... wondering what a black light sounds like....My son made that Kite and it works best with radio or a resistor before the laser for voice unless you buy a very good laser (not the flea market $1.00 ones), don't use indoors with fluorescent lights you hear static( from the tubes flickering 100-120 times a second I think)...years ago I had a client that said the lights talked to her and I did like Jack to show that they did talk and she wasn't crazy .....Kite strip light = fluorescent?
May 31, 2008. 3:45 PMKiteman says:
Yes, strip-lights = fluorescent. They do flicker at around 100-120 Hz (twice the quency of your supply, apparently), which is why they can cause headaches - your eyes try and adjust to the flicker but can't keep up.
Sep 16, 2008. 6:23 AMGoodhart says:
Yes, this is one of the reasons they now put 3 bulbs in office fixtures (at least here in the USA) on different circuits, attempting to cancel out the "flicker to headache effect" :-)
Oct 23, 2009. 9:10 AMrobcull says:
Fur Elise??
Really?
Can you post a video recording of this sound?
Jan 10, 2009. 11:21 AMmskogly says:
I wish I had discovered the secret music in the tea lights, that is really cool.
Dec 30, 2008. 12:08 PMscafool says:
If I put this on a telescope would I be able to hear little stars twinkling away in the night?
May 31, 2008. 7:24 AMmaker12 says:
I did this once a IR remoted played part of the twilight zone theme song! it is landing!
May 26, 2008. 4:17 PMchalky says:
cool!
May 17, 2008. 4:50 PMGorillazMiko says:
Sweet Instructable, I want to do this so I can tell my friends how cool I am listening to light. ;-) +5/5 stars.
May 16, 2008. 10:06 PMA good name says:
Ooo... how about we make a model titanic and leave the candles on so that it's like the band is still playing!
May 16, 2008. 10:05 PMA good name says:
Ooo, next time teach us how to listen to god! That would be soooooooooooooooooooooooooooooooo cool... In fact, I'll make an instructable about it RIGHT NOW! 1: Build giant Radio antenna/transmitter/receiver dish 2: Insert the receiver dish into a speaker 3: Insert the transmitter dish into a microphone 4: You may now talk to god, it may take a while to get the right frequency, and you might need to change around the battery power, but other than that, it works great.
May 16, 2008. 8:27 PMtechnodude92 says:
There could be subliminal messages in my LED tea lights!!! Oh My GOD!!! thats kicka**.
May 16, 2008. 8:37 PMtheburn7 says:
lol
May 16, 2008. 3:55 PMcprocjr says:
wow i didn't know they played music. amazing.
May 16, 2008. 1:22 PMinvisiblelight386 says:
cool, i have that same amp from radio shack, i think i'll do this when i get a chance
May 16, 2008. 1:20 PMalexhalford says:
The idea is pretty good but the thing I was most impressed at was how the instructible was put together, no missing steps, very well explained. Very good in my opinion.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
17
Author:Jack A Lopez
I've built some weird stuff over the years, but most of that stuff has remained unseen by the world outside of me and a few friends. But then one day, one of these friends, he says to me, "Hey Jack, ...
more »
