How to Load 35mm Film to a Holga 120 CFN Camera by Analogue-Chick
Featured
So apparently I wasn't able to acquire 120mm film at local photo stores anywhere here in my place just as I thought. Anyway, knowing the problem I have been reading loads of stuff in the internet and learning the basics of analogue cameras and its innards, I was able to find a way to do 120 cameras with 35mm film and I was kind of bored so... Moreover, what I'm going to show you, I believe, would be applicable to many 120 analogue cameras regardless of the model.
Step 1: WHAT YOU NEED?
1) Holga 120 (any 120 analogue camera)
2) 35mm Film
3) Popsicle Sticks (but you could do it with any material, tongue depressor for example -- anything that can easily be cut to a specified width would work)
4) Pair of Scissors
5) Foil
6) Pencil (any marker)
7) Electrical Tape (any tape would do)
jrfrank says: Sep 1, 2011. 5:18 PM
Good project, could make some interesting wide slides!
diegot says: Aug 25, 2011. 3:42 AM
Wow! All this trouble to turn a medium format to the lowly 35 mm??
There are plenty of places on the web where you could get 120 and 220 film, (Amazon for one).
I don't think it's worth the time and effort to actually get lower quality results.
doodle_m says: Aug 9, 2011. 5:36 AM
How many turns of the spool do you do between exposures?
Analogue-Chick (author) says: Aug 9, 2011. 7:18 AM
I ran a test film to determine just about that and what it revealed after processing is: for one turn, almost half of the image overlaps to the next frame; one and a half turns, one-fourth of the image overlaps to the next frame. So the best thing to go with 35mm film loaded to a Holga 120 CFN camera is two turns although I'm not sure if this applies to all 120 cameras.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
