3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to MAKE a Geico Caveman Costume
My first Instructable!!!!
While watching TV I saw the famous Geico Caveman commercial. I thought to myself what a great Halloween costume idea, so I went to work and took some pics along the way. Hope you enjoy and hopefully this Halloween there will be a bunch of caveman walking the streets!!! Total project cost was about $30.00 excluding some stuff I already had, and it took about two days to complete.
Step 1What you will need
MATERIALS:
For lifecast:
Alginate
plaster bandages
plaster
petroleum jelly
bald cap
drinking straws
another person
For sculpture:
modeling clay
miscellaneous utensils
orange
more plaster
For mask:
liquid latex
wig
spirit gum
makeup
scissors
72 comments
1-40 of 72next »
Oct 11, 2010. 7:36 AMMjPadfoot says:
AWESOME.
Oct 10, 2010. 2:25 PMRaNDoMLeiGH says:
Nice job!
For removing the first plaster face from the second plaster face, as some people have said, coat the entire thing with dishwashing liquid (like palmolive) or with vaseline. Vaseline can break down latex but you probably won't have a problem with that since it mostly soaks into the plaster.
THIN coats of latex + hairdryer = much time saved.
You can also make the forehead, cheeks, and nose in separate pieces. Feather out the edges so they're very thin. When you glue them to your face with spirit gum, melt the edges with acetone (polish remover) but for god's sake KEEP IT OUT OF YOUR EYES and don't breathe it in. Put a small amount in a glass or ceramic bowl or cup and paint it on with a cheapo paintbrush. This will help blend the pieces together a lot better and make the appliances more comfortable to wear, especially around the mouth and corners of the eyes.
The person who suggested putting cotton balls inside the latex has a great idea. You will sweat a lot under a latex mask and this trick will help keep the sweat from pooling up in the brows and nose, which could later result in weirdness when it decides to come out, ha ha.
Spirit gum remover is your friend. Get some when you buy your spirit gum.
The latex at Michael's in the mold-making department is, for this purpose, the same as the stuff you can get from Joe Blasco or Ben Nye and costs about 1/3 less. I wouldn't put it right on my skin, but after the solvent cures, you're just left with the dried latex, and we've never had a problem with cured appliances. Haven't actually tried it on my skin but I would use a cosmetic grade latex for that part.
To lay a beard, paint on a couple of thin layers of latex over the whole area and allow to dry. Paint a thin line of latex where you want to place the hair. Start from the bottom and work your way up. Fan the hair in your fingers and use the end of a toothbrush or paintbrush to embed the hair in the latex. Allow to dry before moving up the cheek or chin for the next line of hair.
For a natural look the top of the beard should be a lot more sparse than the bottom. Pay close attention to the hairline, how it "grows" from the face. If necessary lay in one or two hairs at a time. However, for this costume you probably don't need to be that picky.
Apr 23, 2010. 4:22 PMOdieGiblet says:
Great mask, I just finished making mine and I'm happy with how it came out. Thanks for the idea! But this tutorial is definitely lacking some information which left me scratching my neanderthal scull. I used this site to help me fill in the gaps on how to do it. The site uses all clay in the first mold, but it's pretty much the same thing.
www.dalchem.com.au/
Oct 25, 2009. 9:37 PMZelenVR says:
Any chance someone could post quantities of the supplies needed? Specifically I'm looking the clay and the laytex, but tips on the rest would be great too!  Looking for amounts for each item,  per mask, on the high side if estimates. I'm really new to this and dont want to run short, and I tend to have pretty steep learning curve with this this artistic. Thanks everyone!
Oct 29, 2009. 11:01 AMVessie says:
I started this project last night and it took me 3 times to mix the aliginate correctly. I bought 1lb of alignate, which is enough for about 3 masks. When you mix the alignate with water, make sure you use a 1:1 ratio. I used 16oz (2 cups) warm water with 2 cups alginate powder. On the alignate it told me to use 5.5oz alginate for 16oz water, but they base that on weight, not volume. if you dont have a scale to measure the alginate to 5.5oz, just use a 1:1 ratio. (2 cups water, 2 cups alginate. Note: Make sure you have another person mix the alginate and apply it on your face. Doing it by yourself is pretty impossible. Keep me updated on your mask building venture!
Oct 24, 2009. 10:50 PMqwertyuiop5433 says:
How much alginate do you need to use for the negative. I need to know how much i need to buy.
Oct 22, 2009. 11:25 PMchadsanders says:
dont understand what you put on  the mask here because the alginate is not working to runny then when it gets think u can not sculpt it just wondering ?
Oct 12, 2009. 12:17 PMechuta86 says:
What kind of plaster did you use here? I put plaster over my mold and now I can't seem to separate them. Was I supposed to use alginate to cover it then plaster bandages? Any help would be appreciated!
Oct 13, 2009. 12:41 PMechuta86 says:
OK, FINALLY!!! For those of you who are stuck on step 5 or are confused. On my second try I got it right. Here are some helpful tips:
1) To make your life easier, lay your molded face facing up. Use molding clay and put about 1 inch x 1 inch wall around the base of the face. This will help you use leverage to pry the mold from the plaster at the end.
2) Before you start layering plaster on top, cover your molded face and wall from step 1 with a thin layer of vaseline (I've heard soapy water works or there is a liquid you can get from a ceramic store but for me, vaseline worked great!). Be very thorough and spread nook and cranny.
3) When you prep plaster, be sure to make plenty. You'll want mounds and mounds on top. I think I used about 3 quarts (combined volume) and gave everywhere a good 2-3 inches worth
4) Wait for the plaster to start setting (ie, it just start changing from watery to gooey) before you start putting it on top of the mold.
5) After the plaster has set on top, I used a screw driver to start prying out the inner mold gently along the 1 inch clay wall going in a circular motion. It will start to give slowly and you can just life it out about 1/2 way around.
Oct 5, 2009. 2:28 PMpiper1234 says:
mm i don't see the point... can't notice the difference btween you with n' without mask .... :P hahahaha xD just kidding :D you gimme some ideas thx ; )
Oct 3, 2009. 7:03 PMANTQNUT says:
O_O EPIC!
Oct 3, 2009. 2:32 PMscreeching crow says:
very cool although way too involved for me i think ill just skip the mask
Oct 28, 2008. 7:56 PMfylraen says:
A few words of advice: If you start from scratch this project will cost you a lot more than $30. For me: Latex = $20. Alginate = $12. Clay = $7. Bald cap = $3. Plaster = $7. Wig = $20. Spirit gum = $2. Plaster bandages = $3.
When you get modeling clay, BUY OIL-BASED CLAY. I can't stress this enough! Otherwise the plaster will stick to it and make things impossible.
The liquid latex I bought (Mehron) is pretty thin and takes about 15 minutes to dry a coat, more in the cracks / crevasses. You need dozens of coats of latex in the thick areas that need support (nose, cheek ridges, upper lip, brow ridge) at 15 minutes a shot. It takes a long time. Give yourself plenty of time.
You can use a drinking straw in your mouth to breathe, since you will be cutting out the mouth anyway. Make sure you hold it loosely in the mouth so as not to distort the face. It's much easier for breathing than the nose.
Oct 2, 2009. 11:08 AMthepelton says:
A good oil based clay is Plastiline. (Not sure about the spelling, but it should be available in art supply stores.)
Nov 3, 2008. 8:52 AMrafalobo says:
sidenotes: to make the mask easier to blend in with your face, go easy on the latex around the edges...like the eyes, the sides, or the mouth. when making the first positive cast from the alginate mold...before the plaster sets, try putting a "handle" in place and let the plaster cure around it...that will give you something to pull the clay sculpture from the 2nd plaster cast. a "handle" can be anything...bolt, old cabinet handle...or even a groove you make with your fingers...not so deep so it interferes with the facial features of the cast but just deep enough so you can put at least two fingers in there to pull the clay sculpture away from the plaster. when making the alginate mold from your face, make sure you cover enough real estate..meaning a few inches past the top of your hairline all the way to the underside of your chin, and the sides of your face to your ears....this is to ensure you have a bowl-like mold deep enough to hold the plaster. For smoothing out the clay on the sculpture...try using a sponge with warm water...but be sure you're using oilbased clay or else the clay will turn liquidy.
Nov 3, 2008. 9:39 AMrafalobo says:
also...it's a good idea to stuff some cotton on the inside of the latex mask..in the empty spots like the brow, the nose or the cheekbones...because you will sweat underneath it.
Oct 29, 2008. 10:17 PMcarliman56 says:
Where did you get all this stuff??? I gonna get it today! well I just need to know where to get the plaster, bandages and alginate! help thannxx!!
Oct 30, 2008. 4:25 AMfylraen says:
You can get that stuff at an art store like Utrecht or Dick Blick. Craft stores like Michael's have the bandages and plaster but I didn't find any alginate.
Oct 31, 2008. 1:32 AMcarliman56 says:
thanks!!!
Oct 30, 2008. 7:19 PMrafalobo says:
also at Douglas & Sturgess in San Francisco or Richmond, www.artstuf.com
Oct 31, 2008. 1:31 AMcarliman56 says:
thank you guys!!
Oct 2, 2009. 7:33 AMalex-sharetskiy says:
That is awesome! great job!
Oct 1, 2009. 11:58 PMOuroborous says:
Ha ha! That's amazing! I must admit that I'm thoroughly sick of those caveman commercials, and the gecko ones for that matter, but that costume is awesome nonetheless.
Feb 14, 2009. 11:25 PMLt. Commander Richie says:
I've been meaning to do something like this to make a Wraith face, thank you for posting!
Dec 26, 2008. 3:57 PMpurplekitty says:
Amazing! You should walk down the street and the malls and stuff and act like him that would be so funny looking at the peoples faces. "It's the caveman!" xD
Oct 31, 2008. 3:55 AMfylraen says:
You can do the beard creation step on your positive. It's a lot easier.
Oct 27, 2008. 7:24 PMMonteB says:
I got it to come out but, all the clay was stuck to the inside. That was a pain to get out! I did read on another site to coat the whole positive with a layer of dish soap so I did that. Then a shook the heck out of it to pop off the plaster once it was dry. I will post a pic of my final look once its done.
Oct 27, 2008. 8:18 PMrafalobo says:
so you applied the dishsoap to the positive clay sculpture before you added the plaster on top? And before adding the plaster, did you mix it normally (2:1 plaster/water by volume)? I saw a vid on youtube that showed a clay barrier around the positive and the plaster was poured onto the positive within the barrier...and it made it easier to separate the negative from the positive....also I think you're actually supposed to use a water-based clay so it doesn't stick to the inside of the negative. But of course I used an oil-based clay like mostly everone else because it wasn't mentioned anywhere to use water-based. lol
Oct 27, 2008. 10:31 AMMonteB says:
this was a fantastic idea but I'm having problems getting the molded face back out if the plaster!? Anyone have any ideas???
Oct 27, 2008. 7:03 PMrafalobo says:
maybe you have to break it out...but then you might end up breaking the whole thing...i'm having trouble with this also. step 5 sux! -_-
Oct 25, 2008. 5:27 AMphendyr says:
how did you prevent the 2nd casting, after sculpting, from sticking to the clay and be able to pull them apart? I was working on this, and at that point, I could not separate the two, resulting in a broken forehead and nose :( now I gotta try and glue it all back together and hope I can fabricate something to rebuild the nose structure before applying latex.... great work though, looks great :)
Oct 27, 2008. 7:01 PMrafalobo says:
I'm having the same problem....actually I started off with a small amount of plaster first and when I noticed it was sticking hard to the clay I immediately washed off the plaster and resculpted the clay. Now I'm stuck and don't know how to go about this. I'm guessing that applying a release agent or petroleum jelly to the sculpture before adding the plaster might make the 2nd cast easier to remove. wish me luck
Oct 25, 2008. 3:25 PMjomamasdad says:
this instructable is so easy, a caveman could do it!
Oct 20, 2008. 3:59 PMmomm says:
i bet u didnt make anything, ur the guy that plays the cave man!!!! :P
Oct 22, 2008. 11:14 AMhornbadoing says:
he is
Oct 19, 2008. 8:50 PMrafalobo says:
regarding step 5: if you add plaster onto the sculpture, won't it stick to or merge with the eyes and other plastered pieces? or do you just mix the plaster so it's really thick? When I mixed the plaster for the original alginate mold, I used a 2:1 ratio by volume (powder/water) and it came out thin and easy to pour into the alginate mold....should it be thicker when you "plop" it onto the clay sculpture? thanks.
Oct 19, 2008. 12:39 PMFillitup4 says:
ohh wow that's amazing
Oct 19, 2008. 12:33 PMmatthewabel says:
Man, what an excellent project. And a great east-to-read instructable.
Oct 19, 2008. 7:23 AMbassclarinet23 says:
That's really good.
Oct 18, 2008. 10:50 PMcantthinkof bettername says:
That looks just like the guy on tv. good job.
1-40 of 72next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
44
Author:BeerBellyJoe
I love brewing and drinking my own Beer (hence the name), building robots, animatronics, working on my car, and building random things.
