How to Make 400Watt Brushless Mini Sumo
 by fluxuss
Contest Winner
This instructable is 18+ category in contest and will show you how to make a Mini sumo using brushless motors and brushless ESC's:
First of all, this project was a true challenge for me to fit all componenets in 10x10 cm projection area and not exceeding the 500gr weight limit. Because of its speed and power I call it Mach 1.0, pretty cool name huh? :)
Weight is an another issue when it comes to mini-sumo's. Every component used in project are precisley weighed before adding them to bot.
There is no gearbox on motors unlike nearly all of the entarants in robot contests do. That makes this bot unique and extraordinary.
Anyway this is enough for praising part, let's get it started.
For more info you can take a look at my blog: www.ceyhunderinbogaz.com
Step 1: Parts and Tools
Making the bot was easy, hardest part was finding the money and time for this project.
When it comes to Brushless technology, you need a thick wallet with nice green papers in it.
Luckily our Chinese friends working hard to make this parts cheaper every day.
PARTS:
2x Turnigy 35AMP CAR ESC
2x NTM 910KV outrunner Brushless motor
1x Turnigy Nano-tech 1300mAh 25-50c Li-po
1x Arduino Duemilanove
1x Laser cutted Bot frame
2x Ultrasonic Sensors for opponent sensing
2x QRD1114 contrast sensors
Total cost is approximately 150$
veckoff says: Sep 28, 2012. 1:47 PM
Excellent design, congratulations, will be my next project,thanks for the tutorial
ramicaza says: Mar 16, 2012. 10:43 PM
or could I just connect the ground and signal to the esc?
ramicaza says: Mar 16, 2012. 10:30 PM
if I have a an esc that also powers the receiver, wouldn't this damage the arduino? what could I do to prevent this?
Gilius says: Mar 16, 2012. 7:50 AM
Are those type of brushless motors AC or DC?
TedRobotBuilder says: Mar 4, 2012. 11:54 AM
Do you have any video of it fighting other bots? Would be cool to see! XD
bld says: Sep 30, 2011. 1:43 AM
How fast is this minisumo robot?
The dohyo has 77cm diamter, how much time it takes to cross the dohyo...?
fluxuss (author) in reply to bldSep 30, 2011. 6:23 AM
I didn't use a chronometer but it doesn't take more time than closing your eyelids :)
Main problem is stability, too much power for a minisumo :S
bld in reply to fluxussSep 30, 2011. 10:03 AM
I think you need very fast sensors, otherwise the robot can easily go out of the ring.
frank26080115 says: Mar 21, 2011. 4:40 PM
That's a clever way of using outrunners!
fluxuss (author) in reply to frank26080115Mar 21, 2011. 5:14 PM
Thanks for the compliment :)
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
