How to Make 6-Pointed Paper Snowflakes by ReadsInTrees
Featured
This step by step guide will teach you how to make SIX pointed paper snowflakes. Most people make (and most how-tos teach) snowflakes with four or eight points. Real snowflakes in nature form with six points (or occasionally three if they formed weird) so I choose to make my own with six points. I taught myself this technique in high school and have been making paper snowflakes around Christmas time ever since.
All you will need for this is paper and scissors. Some people like to use fancy paper, but I use plain white copy paper because somehow the simplicity of white is more beautiful to me.
If you want to view a gallery of my snowflakes, see me on Flickr: Paper Snowflake Gallery.
Remember to rate this Instructable!
Step 1: Step 1
First, begin with a square piece of copy paper. I usually make two snowflakes for every 8.5"x11" piece of paper, so I first cut the paper in half, and then make a square from each half. This makes a snowflake about 5" across. If you're just learning to make snowflakes, using a full piece of paper for each snowflake may be easier to practice with.
You can make a square from a rectangular piece of paper simply by folding one corner down to form an isosceles triangle (like the one in the next step) and trimming off the excess paper.
Step 2: Step 2
Fold the square of paper diagonally to make a triangle.
Step 3: Step 3
Fold this larger triangle in half to make a smaller triangle.
Step 4: Step 4
Imagine the triangle in thirds, and fold the right third over, as shown. If you want to be precise and have a protractor, each "third" in this step is a 30 degree angle.
See the explanation above, from a worksheet I made up, which should help to explain folding in thirds a little better.
Step 5: Step 5
Fold the left third over. Try to get all of the folds to line up as close as possible for the most symmetrical snowflake.
Step 6: Step 6
Cut off the top of the paper at an angle. Make sure to cut if off so that all remaining layers of paper are equal. Cutting at an angle is what makes the points of the snowflake. Eventually, you'll learn to cut at different angles to make snowflakes with points that are more or less sharp.
Step 7: Step 7
This is where your imagination comes in. Begin cutting away from the sides of the paper. Usually, cutting small triangles from the sides is easiest, but don't forget to try other shapes.
For this snowflake, I altered the top edge a little to make my points a different shape. I also cut out a piece with a "spiky" edge. Use your imagination!
 I don't use patterns for my snowflakes: I just cut as I go. My snowflakes are never the same because I don't usually plan out my snowflakes. Sometimes I find a new cut or shape that I like, and I may use the same technique on a different snowflake, but I don't copy the whole snowflake.
Step 8: Step 8:The Reveal
Unfold the paper very carefully.
The snowflake will not lay flat right away, so I like to tuck them between the pages of a book for a while before displaying them. I have also ironed them (between two pieces of plain paper) to make them extra flat. Watch out though, because paper can get very hot to the touch when ironed (don't use steam!) so be sure to let it cool for a second before handling the paper, and as always excercise caution to avoid fire and burns. Ironing them also seems to make them a tiny bit stiffer, which could be good if you want to hang them rather than tape them to a surface.
Step 9: Tips!
Materials:
- Make sure you have sharp scissors and clean hands. Dirty hands make for dingy snowflakes!
-Some people recommend using cuticle scissors so that you can make even more intricate snowflakes. I don't like this for two reasons. First, cuticle scissors are not comfortable in your hand. A comfortable grip is essential. Second, it is possible to get too intricate. Too many tiny snips and not enough shaping will just make your snowflakes look like lace doilies.
-Snowflake experts recommend using tracing paper and an X-acto knife to make snowflakes, to make them even more delicate and more perfectly symmetrical. However, I still like plain paper and scissors, since those are things that anyone has and you can use them with kids.
-Some people like to use wrapping paper or other fancy paper to make their snowflakes. Use whatever you like to create the desired effect. I stick with plain white copy paper because somehow I get a lot of satisfaction from creating something so beautiful from something so ordinary.
Making Snowflakes:
-I usually make my snowflakes while sitting down on a couch or chair with a coffee table in front of me, and a small trash can between my knees. This way I can lean forward to fold the paper on the table, and then sit up and snip bits of paper into the trash can. This makes less mess.
-When folding, steps 4-5 are the hardest, when you have to try and estimate thirds. Often, you'll fold the second third over, only to discover that it doesn't line up exactly in thirds. You'll have to unfold and refold until it's as exact as you can get it. The closer to exact thirds you can get it, the more symmetrical your snowflake will be. As it is, the thickness of the paper and the amount of folding that you do will make it so that making a precisely symmetrical snowflake is almost impossible. This will be most obvious in the center of the snowflake: look at some of mine. The star in the middle of some is not perfectly symmetrical. It happens. Real snowflakes have defects too, so don't worry about it.
-Avoid what I call "blank space". This is when you're cutting your snowflake in Step 7, and you leave behind big spaces of blank paper in your snowflake. Generally, anything thicker than 1/4th of an inch gets cut down into a thinner line, or by decorated it in some way (like by making tiny triangle snips all along the edge to give it "teeth"). Otherwise, when you open your snowflake, it will have thick, clunky lines instead of nice delicate ones. Sometimes thicker lines do create a different effect when contrasted with thinner lines, but use sparingly.
Decorating With Snowflakes:
-A tiny piece of double-sided tape behind each point is a good way to stick them to a surface. I love to put mine on windows so that they're visible from inside and out. They show up beautifully at night against the dark glass.
-These can be hung from the ceiling, but be careful because they are delicate. It may be wise to cut some with thicker lines for support (imagine making a skeleton for the snowflake: thicker lines for structure surrounded by the delicate parts for show) if you want to hang them. White or invisible thread, or fishing line, works great.
-Use your practice snowflakes to decorate gifts instead of a bow. I like taping a single snowflake to a gift, and then putting a plain gift tag on top of it. The lacy looking snowflake makes a pretty backdrop for the tag.
-Save the end scraps of paper from when you cut the original sheet of paper into a square. Use these little pieces to make tiny simple snowflakes that you can place around your larger snowflakes when decorating. This makes a "sprinkle" effect that looks wonderful, and you can fill more space without using up all your larger snowflakes. I didn't discover this idea until after the picture above was taken.
Step 10: Analyzing a Snowflake
If you do want to try and copy a snowflake that you see, or at least get an idea of how to make one similar, try to visualize the slice of the snowflake that represents the completely folded paper. This is one slice out of twelve symmetrical slices. It will be a line that cuts through the middle of one point, and intersects with a line cut though the middle of the "valley" between it and the adjacent point. If it makes it easier, pretend that the snowflake is a clock and the lines you're imagining are the hands when it's one o'clock. See picture.
This slice of the snowflake shows what your cuts should look like if you want a snowflake that looks like this. It may be easier to visualize if you look at the black (cut out) spaces and think about those shapes being cut away.
Step 11: Replicating a Real Snowflake
From time to time I try and copy a real snowflake that I see in a book or online. It's impossible to copy an actual snow crystal exactly because they're simply too intricate, they're 3-D, and some parts of the snowflake are attached with a layer of ice so thin that it looks invisible.....if you tried to copy one exactly, it would fall apart. However, you can still try to mimic the form of a real snowflake.
Real snowflakes often have large areas of "blank space" that don't look very good when rendered in paper. A flip through a snowflake photography book shows that quite a few snowflakes form as just a simple hexagon with few details. If the snowflake you're copying has a lot of blank space, embellish it anyway. Since it can't be an exact replica, it might as well be pretty!
Basically, just use the technique from step 10. Imagine the how a real snowflake would look if it were a slice of a pie. Think of the clock hands at 1 o'clock.
Above are two examples of snowflakes that I've tried to replicate. I've added a second view of each with the "slice" highlighted.
1-40 of 134Next »
Olympus Architect says: Jan 7, 2013. 1:42 PM
Annabeth doesn't get confused. Just saying. ;)
annabeth of camp half-blood says: Dec 10, 2012. 9:34 AM
how do you imagine a triangle in thirds i am very confused.
ReadsInTrees (author) says: Dec 27, 2012. 12:49 PM
I have added a second picture to hopefully make this step easier to understand.
tphillips14 says: Dec 22, 2012. 5:59 PM
Thank you so much for posting and sharing this!! We are making these as a Girl Scout project to send to the children at Sandy Hook Elementary school.
ReadsInTrees (author) says: Dec 26, 2012. 4:54 AM
I also hosted a paper snowflake workshop at my local library to make snowflakes to send to Sandy Hook. It was very last minute, but we still had over 50 people show up (lots of kids), we made 160 snowflakes, and I think a few people left with a new skill up their sleeve.
Throckmorzog says: Dec 25, 2012. 5:51 PM
Great instructions and beautiful scissor work!! Spent Christmas eve making these with nieces and nephews. Thank you, my windows now look spectacular at almost no cost, and we had so much fun. : )
ReadsInTrees (author) says: Dec 26, 2012. 4:47 AM
Glad that everyone had fun! I'd love to see pictures of your windows!
sturner18 says: Dec 22, 2012. 4:12 PM
Thanks so much for this, just putting finishing touches on a Santa Sack and wanted to add snowflakes, couldnt quite remember how to do this. Worked Fab, great instructions and used White Fabric filling to give a a realistic feel. Thanks Again.
yongeeks says: Dec 19, 2012. 9:10 AM
Thank you. I really enjoyed making these!
mhudson11 says: Dec 5, 2012. 2:42 PM
Awesome! Thank you!
PaganRaven says: Nov 29, 2012. 3:01 PM
I have to tell you that your snowflakes are gorgeous! I've tried all my life to do this and they never look quite as good. I know you posted this a year ago, and I'm a late starter on Instructables (totally addicted now) but I hope at some point you do read this. Merry Yule and a warm winter Solstice!!
ReadsInTrees (author) says: Nov 29, 2012. 3:58 PM
Thank you! I hope my instructions and tips help you make beautiful snowflakes of your own! Happy Solstice!
Dejaykomm says: Dec 8, 2011. 10:26 AM
My first attempts at the 6 point snowflake. :-) comments appreciated. :-)
amerari says: Jul 8, 2012. 9:34 PM
beautiful
Dejaykomm says: Oct 11, 2012. 9:55 AM
:-) Thankyou.
ReadsInTrees (author) says: Dec 8, 2011. 11:20 AM
Nice job! I hope my instructions and tips were helpful.
Dejaykomm says: Dec 8, 2011. 12:09 PM
it was your tutoring and design styles that led the way. :-)
Swirlysmile says: Dec 8, 2011. 11:18 AM
Beautiful!
Dejaykomm says: Oct 11, 2012. 9:56 AM
:-) Thankyou!!
reganbella says: Jun 27, 2012. 10:51 AM
I think I folded mine wrong. Instead of turning out circular, like a snowflake would be, mine turned out rectangular. Yours are great though!!! They look so intricate!
karmar22 says: Dec 13, 2010. 2:00 AM
I must be really stupid because mine turned out completely hollow and looked nothing like a snowflake!
pammybear says: Feb 2, 2012. 4:33 PM
karmar22 - I did exactly the same thing. I found out I was cutting the wrong piece. I thought I was supposed to cut the top part, because that's what it looks like in the picture, but if you cut the bottom plain triangle that is cut off, it comes out really nice.
Dr.Bill says: Dec 24, 2011. 7:42 PM
Thank You Thank You My Wife Loves Me Again !
Mele Kalikimaka and Houoli Maka Hiki Hou !
Aloha !
MommasArtMess says: Dec 22, 2011. 7:31 PM
Good job on the directions! I teach art and include both this method (which my mom shared when I was five or six years old) and one that uses a circle. I love sharing the patterns with kids and letting them feel superior that their flakes are *correct* multiples of three.
Imjetta says: Dec 21, 2011. 11:10 PM
Ohhhhh dreamy! These are so much prettier than Martha Stewarts! Thank you!
ReadsInTrees (author) says: Dec 22, 2011. 5:11 AM
Haha, thanks! You know it does irk me a little that when you Google "How To Make Paper Snowflakes" my how-to shows up at #3 and HERS is at #2. Argh.
dangjena says: Dec 20, 2011. 5:19 AM
This was amazing! Super instructions and beautiful work. Well done, friend.
jbrecken says: Dec 15, 2011. 9:12 AM
I decorated my cubicle one year with Post-It notes transformed into snowflakes using more or less this technique. The only difference is that with the smaller paper there wasn't room for too many cuts.
maggieelrod says: Dec 15, 2011. 6:56 AM
just wanted to thank you for your time to go into such detail to explain how to do this. Merry Christmas!
Maggie Elrod
ReadsInTrees (author) says: Dec 15, 2011. 8:12 AM
You're welcome! I hope you're having fun making snowflakes!
designteach says: Dec 15, 2011. 7:05 AM
Excellent instructions! Enjoyed making these in class today!
sconnaire618 says: Dec 8, 2011. 6:53 PM
I love this - so does my 9 year-old. Our window is well on it's way to a winter wonderland! Thank you for taking the time to instruct!
This is a GREAT instructable. thank you! I'd forgotten how to fold. Now I just need to be more adventurous in my cuts. I predict a snow day in my house during winter school break for my daughter. :D
daguilar4 says: Dec 8, 2011. 11:03 AM
Made mine thanks for this I loved it , posted on my facebook
https://fbcdn-sphotos-a.akamaihd.net/hphotos-ak-ash4/392244_2187605741185_1578316978_31622056_1266856817_n.jpg
Dejaykomm says: Dec 8, 2011. 7:54 AM
Best snowflake ins'ble I have seen! Made 6 already! Think I am gonna need more paper!! :-)
dwirsz says: Dec 6, 2011. 11:53 AM
First attempt
ReadsInTrees (author) says: Dec 6, 2011. 3:30 PM
Excellent for a first attempt. Must've had a good teacher!
dwirsz says: Dec 6, 2011. 11:50 AM
Very nice instruction guide. Very easy to follow. I have been making other kinds of snow flakes for years, but this is my first attempt at a 6 pointer. Thought I would upload a pic of my first attempt at your six point style... Let me know what you think.
lgrochowsky says: Dec 4, 2011. 2:10 PM
I love your directions and that is a beautiful snowflake.
ReadsInTrees (author) says: Nov 16, 2011. 6:20 PM
If you guys liked this one, feel free to browse my gallery of snowflakes on Flickr. http://www.flickr.com/photos/jmdsnowflakes/sets/
1-40 of 134Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
