Introduction: How to Make 6-Pointed Paper Snowflakes
This step by step guide will teach you how to make SIX pointed paper snowflakes. Most people make (and most how-tos teach) snowflakes with four or eight points. Real snowflakes in nature form with six points (or occasionally three if they formed weird) so I choose to make my own with six points.
Be sure that you follow each step carefully. Each step is one fold, but some steps have two pictures shown to help explain things, so please read the description underneath.
Instructables.com doesn't always show all of the steps on one page, so hit "next" to go on to the next step. Steps 4-6 tend to be the trickiest, so step 6 has an extra image to hopefully help explain better for those who are having difficulty.
All you will need for this is paper and scissors. Some people like to use fancy paper, but I use plain white copy paper because somehow the simplicity of white is more beautiful to me.
If you want to view a gallery of my snowflakes, see me on Flickr: Paper Snowflake Gallery.
Remember to rate this Instructable!
Step 1: Start With a Square
First, begin with a square piece of copy paper.
I have outlined the edges of my paper in blue to make it easier to follow along with the steps. As I fold, I keep the paper in place, so you shouldn't need to rotate or flip over the paper to follow along (unless otherwise stated). Just fold it exactly as it shows.
(TO MAKE A SQUARE: You can make a square from a rectangular piece of paper simply by folding one corner down to form an isosceles triangle and trimming off the excess paper. See second picture.)
I usually make two snowflakes for every 8.5"x11" piece of paper, so I first cut the paper in half, and then make a square from each half. This makes a snowflake about 5" across. If you're just learning to make snowflakes, using a full piece of paper for each snowflake may be easier to practice with.
Step 2: Fold in Half Diagonally.
Fold the square of paper diagonally to make a triangle.
(Note that I have marked the center of the paper square with a yellow star, as well as outlines of what the paper looked like before it was folded. This is just to help make a reference point for following along.)
Step 3: Fold in Half Again.
Fold this larger triangle in half to make a smaller triangle.
Step 4: Fold One Third.
Imagine this triangle in thirds (as shown in the first picture), and then fold the right "third" over, as shown in the second picture. If you want to be precise and have a protractor, each "third" in this step is a 30 degree angle.
Step 5: Fold Again.
Fold the left third over. Try to get all of the folds to line up as close as possible for the most symmetrical snowflake.
Step 6: Cut the "top" Off at an Angle.
Flip your folded paper over so that you're looking at the back. Then, cut off the top of the paper at an angle. Make sure to cut if off so that all remaining layers of paper are equal. As you can see, I'm basically cutting off all of those excess blue edges.
Cutting at an angle is what makes the points of the snowflake. Eventually, you'll learn to cut at different angles to make snowflakes with points that are more or less sharp.
BONUS: The extra image shown in this step is from a worksheet I made for a class, which just re-explains steps 4-6 for those who may have a harder time visualizing the "fold in thirds" part. If you've already got the hang of it, just ignore the second picture and continue on to step 7.
Step 7: Shape It!
This is where your imagination comes in. Begin cutting away from the sides of the paper. Usually, cutting small triangles from the sides is easiest, but don't forget to try other shapes.
Be careful not to cut all the way from one side to the other, or else you'll chop your snowflake in half!
In this particular snowflake, I cut the top edge (that original angle that we chopped off) to make the points turn out differently, I added some spiky cuts around the middle there, and I snipped off the very bottom at an angle (which will make a star shape in the middle of the finished snowflake).
I don't use patterns for my snowflakes: I just cut as I go. My snowflakes are never the same because I don't usually plan out my snowflakes. Sometimes I find a new cut or shape that I like, and I may use the same technique on a different snowflake, but I don't copy the whole snowflake.
Step 8: Unfold to Reveal!
Unfold the paper very carefully.
Ta da!
The snowflake will not lay flat right away, so I like to tuck them between the pages of a book for a while before displaying them. I have also ironed them (between two pieces of plain paper) to make them extra flat. Watch out though, because paper can get very hot to the touch when ironed (don't use steam!) so be sure to let it cool for a second before handling the paper, and as always excercise caution to avoid fire and burns. Ironing them also seems to make them a tiny bit stiffer, which could be good if you want to hang them rather than tape them to a surface.
Step 9: Tips!
Materials:
- Make sure you have sharp scissors and clean hands. Dirty hands make for dingy snowflakes!
-Some people recommend using cuticle scissors so that you can make even more intricate snowflakes. I don't like this for two reasons. First, cuticle scissors are not comfortable in your hand. A comfortable grip is essential. Second, it is possible to get too intricate. Too many tiny snips and not enough shaping will just make your snowflakes look like lace doilies.
-Snowflake experts recommend using tracing paper and an X-acto knife to make snowflakes, to make them even more delicate and more perfectly symmetrical. However, I still like plain paper and scissors, since those are things that anyone has and you can use them with kids.
-Some people like to use wrapping paper or other fancy paper to make their snowflakes. Use whatever you like to create the desired effect. I stick with plain white copy paper because somehow I get a lot of satisfaction from creating something so beautiful from something so ordinary.
Making Snowflakes:
-I usually make my snowflakes while sitting down on a couch or chair with a coffee table in front of me, and a small trash can between my knees. This way I can lean forward to fold the paper on the table, and then sit up and snip bits of paper into the trash can. This makes less mess.
-When folding, steps 4-5 are the hardest, when you have to try and estimate thirds. Often, you'll fold the second third over, only to discover that it doesn't line up exactly in thirds. You'll have to unfold and refold until it's as exact as you can get it. The closer to exact thirds you can get it, the more symmetrical your snowflake will be. As it is, the thickness of the paper and the amount of folding that you do will make it so that making a precisely symmetrical snowflake is almost impossible. This will be most obvious in the center of the snowflake: look at some of mine. The star in the middle of some is not perfectly symmetrical. It happens. Real snowflakes have defects too, so don't worry about it.
-Avoid what I call "blank space". This is when you're cutting your snowflake in Step 7, and you leave behind big spaces of blank paper in your snowflake. Generally, anything thicker than 1/4th of an inch gets cut down into a thinner line, or by decorated it in some way (like by making tiny triangle snips all along the edge to give it "teeth"). Otherwise, when you open your snowflake, it will have thick, clunky lines instead of nice delicate ones. Sometimes thicker lines do create a different effect when contrasted with thinner lines, but use sparingly.
Decorating With Snowflakes:
-A tiny piece of double-sided tape behind each point is a good way to stick them to a surface. I love to put mine on windows so that they're visible from inside and out. They show up beautifully at night against the dark glass.
-These can be hung from the ceiling, but be careful because they are delicate. It may be wise to cut some with thicker lines for support (imagine making a skeleton for the snowflake: thicker lines for structure surrounded by the delicate parts for show) if you want to hang them. White or invisible thread, or fishing line, works great.
-Use your practice snowflakes to decorate gifts instead of a bow. I like taping a single snowflake to a gift, and then putting a plain gift tag on top of it. The lacy looking snowflake makes a pretty backdrop for the tag.
-Save the end scraps of paper from when you cut the original sheet of paper into a square. Use these little pieces to make tiny simple snowflakes that you can place around your larger snowflakes when decorating. This makes a "sprinkle" effect that looks wonderful, and you can fill more space without using up all your larger snowflakes. I didn't discover this idea until after the picture above was taken.
