How to Make a Small Spring Cannon
37,838
23
21
Published
Introduction: How to Make a Small Spring Cannon
For shooting marbles, erasers, pickle harpoons, and other small things.
Step 1: Gather Supplies
you will need these things for this project;
wire hangar
spring
1/2 in copper pipe
1/2 in wooden dowel
tools;
bandsaw (or hacksaw)
wire cutters
pliers
drill
Step 2: Cut the Pipe
cut about five inches off of the pipe.
about 1 1/2 inches down the pipe cut halfway through
then cut down the middle of it until you reach the second cut.
it should look like this.
Step 3: Make the Spring Assembly
cut a 1/4 in piece off the dowel
drill a 1/16 hole in the center.
cut the straight part of the wire hanger
use the pliers to bend 1/4 in of the end at a right angle
put the wire through the wood an the spring
Step 4: Finish It
use the pliers to crush the pipe at the 1/2 cut part. (not all the way)
put the spring assembly in the pipe.
pull it down to where it starts to compress the spring.
and bend the wire.
cut the excess wire
Step 5: How to Fire
pull the bent wire back and turn it so it catches on the half pipe
load it
give the bent wire a half turn to shoot
    • Planter Challenge
      Planter Challenge
    • Stick It! Contest
      Stick It! Contest
    21 Comments
    what size spring did you use
    awesome. Im making a pickle harpoon. but i need to know, where did the spring come from? 8/10
    ...Pickle Harpoon?
    Yep, Pickle Harpoon. :D
    PLEASE POST AN INSTRUCTABLE ON IT!
    Go to a lumber store or go to Home Depo and you will have lots of sizes and tentions. they are about 1 to 3 dollors.
    I actually tried my home depot, they didn't have it. Maybe it depends on what part of the country you're in.
    Nice job! 8/10. What/where did you get that spring from?
    Oh how i love this. ButONE thing, this is somewhat like camster911 bb gun thingy!?!?!?!?!? i dunno wat ver good job
    try to make a much larger one with aam old car spring and a winch
    When i was small my mates dad made one of these but it had hadles. I have always want to know how to make one. Nice1
    I don't understand this one. How does the clothes hanger do anything? Does it pull the spring back?
    yup, the spring is between the crushed end of the pipe and the piece of dowel. You pull the end of the hanger piece back to load the spring, and turn it around so it's hanging on the extended piece of the pipe to ... cock it? (terminology fails me) To fire it, you push (turn) the hanger wire off the ledge of the pipe to let the projectile fly.
    you should make one big enough to use an old spring from an airsoft gun (i would use two) and one verry good place to get springs is your local hobby shop under rc car parts
    i used airsoft bb's because i made my gun from straws
    i just made one and it works out great but what other things can it shoot
