Introduction: How to Make Animated Led Sign Board
Hello everyone,
This is akash from how to bro youtube channel....
I will show you how you can make a simple animated led sign board at home easily......
Before enter the project first watch the video.....
Step 1: Design& Order the Pcb
In this project I make the pcb using easyeda tool.....
& order the pcb on jlcpcb.com
they provide good quality pcb at very cheap prices.....
I order the yellow colour pcb.....but they provide 10 green colour of pcb under $2 at first order.....
This is the cheapest deal anyone can get....
To order the pcb first open jlcpcb.com....
then click on layers according to your choice....& then upload your gerber file...
Choose your quantity ,colour etc.... & pay your order....
Gerber file-https://drive.google.com/file/d/1KO6CHg2762UhBTKQGkZCapWYavH7Czls/view?usp=sharing
Arduino circuit-https://drive.google.com/file/d/0B6lRKp5uKbSbY2JmVFhVU19RZVE/view
Step 2: Components Required
Here I use 5 channel.....but you can use upto 12 channel according to your requirement.....
Components list......
1. Leds
2. 22pf capacitor*2
3. arduino uno
4. 5v power supply...you can use your mobile charger
5. wires for led soldering
6. bd139 transistor*5...you can use any npn transistor
7. 16mhz crystal
8. vero board for name making
9. 1k resistor*5
10. 10k resistor
11. 28 pin ic base (optional)
Tools....
1. Soldering iron with flux
2. wire cutter
3. electrical tape
Step 3: Arduino Programming
Connect the programming cable to arduino & connect it to you pc or laptop.....
Next open the arduino Ide ....then copy the program & paste it to arduino ide..
Make sure the board is selected on arduino uno model
Now upload the code & disconnect the cable after the uploading.....
Here is the arduino program for 5 channel....
https://drive.google.com/file/d/0B6lRKp5uKbSbX195al81SVoxYlljS1Rud2RFMjRyeC1tZUlJ/view
Step 4: Connect All the Components
Now connect all the components to the pcb & solder it carefully......
Step 5: Build You Led Sign
Connect all the leds in a manner,so will look like a word......
Remember all the leds will be connect in parallel connection......
Step 6: Connect the Power Supply
Now connect your 5v power supply to the board....
You can use any kind of power supply according to your choice.....
N:b> If you face any power issue, in that case use a 1000uf capcitor across the power supply it will help to filter the power input to the board....
Step 7: You Are Done
Now you are ready to go.....
You can use it to anywhere....
Also you can modify the whole setup according to your need...
Don't forget to subscribe my youtube channel...
My youtube channel-How to Bro
https://www.youtube.com/channel/UC8Af_aeyqsQijTBXTguaG3Q
Thanks for visiting this page......
