3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Make Anything (Using Acrylic and Machine Screws)
Step 3The Component Pieces & Nuts & Bolts
There are only 2 shapes required.
The T-Cutout
  • This is the piece the machine screw extends into, a nut catching in the large cutout portion.
The RCR Slot (Rectangle-Circle-Rectangle)
  • The cutout the T-Cutout slots into.
To use, simply download the template attached to this step (03-TBOL-T-Slot Template.cdr for Corel Draw or 03-TBOL-T-Slot Template.svg for InkScape)
The Nuts & Bolts
Putting everything together is as simple as a single machine screw and matching nut. McMaster Carr is a great source for these.
2 comments
Jun 20, 2009. 11:03 AMFourthDr says:
Hi Stuart: I was just trying to replicate your technique for making t-slot parts using the above templates (03-TBOL-T-Slot Template.cdr and 03-TBOL-T-Slot Template.svg) and there seems to be a problem with those templates. In the above screen shot of your computer screen the three template items are shown centered and much larger that in the actual template. In fact the three boxes are located at bottom left about two inches off the page and one inch off the page at the bottom. After several attempts to correct this, I was unsuccessful. I tried using both Inkscape and CorelDraw X4 thinking maybe Inkscape was not handling the file correctly. But after getting a copy of CorelDraw the problem persisted. My conclusion is that the templates must be corrupted or need some earlier version of CorelDraw to display properly. Would you please check the template and upload new copies or let me know what I am doing wrong? Regards
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
408
Author:oomlout
