3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Make Anything (Using Acrylic and Machine Screws)
Step 5Adding More Pieces
Adding More Pieces
Sadly you can only build so much using just T-Cutouts and RCR-Slots. However one of the best things about laser cutting is if you have anything with mounting holes, and a pair of calipers, you can quickly draw up a mounting hole for it.
I've Compiled a file with the main cutouts we use in our products.
The Cutouts:
  • RC Servo
  • Mini RC Servo
  • LED
  • NEMA 23 Motor
  • Skate Bearing
  • MicroSwitch
  • Arduino Diecimiela
  • Pololu Servo Controller
(cutout templates available below)
1 comment
Sep 30, 2011. 1:42 PMtechmonster says:
is there any way i could possibly do this without a laser cutter?! is there any possible method i could use to cut this out with a dremel?
Dec 8, 2011. 6:10 AMpfred2 says:
Yeah I cracked up when I read the line, "All that is required is an idea, some drawing software, and access to a laser cutter."
I pretty much stopped reading at that point.
I wonder if burning acrylic plastic produces Hydrogen Cyanide? Apparently it does. So I think I'll pass on lasering acrylic. Even if how lasers cut is by radiation. Not like I have a laser to cut with anyways.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
408
Author:oomlout
