Introduction: How to Make Arduino Based Mini CNC Plotter Using DVD Drive
this a mini CNC 2D plotter made from old DVD drive and L293D motor shield very cheap but intresting
let see how to make
It is very easy to make all the step by step procedure is mention in this instructable
Step 1: Video of CNC Machine Working
Lets see the video this video also cover step by step procedure how to assemble the machine
Step 2: Material Need for This Project
1) 2 X SCRAP DVD DRIVE
2) 1 X ARDUINO UNO R3 / ARDUINO MEGA
3) 1 X L293D MOTOR SHIELD
4) 1 X SERVO MOTOR (TOWER PRO 9G)
5) JUMPER WIRES
6) SOME HARDWARE NUT BOTS ETC
7) DOUBLE SIDE 3M TAPE
Librairy For Adafruit Shield Driver Motors extract the file and past them to arduino/libraries
Step 3: Assembling the Machine
Open the scrap DVD Drive and remove internal moving tray..
This tray having stepper mechanism on it this will act as our X-axis & Y-axis.
Go through the attached pictures for understanding how to assemble your machine.
make hole on empty DVD drive case mount our X-axis and Y-axis on respective DVD case with the help of nut bolts.
Now place them perpendicular
Step 4: Wiring Details
watch the picture carefully and wire components accordingly
Step 5: CNC Code for Arduino
upload the code to arduino using arduino IDE
Step 6: G Code
To make gcode files that are compatible with this cnc machine you have to use the Inkscape.
Inkscape is professional quality vector graphics software which runs on Windows, Mac OS X and Linux.
It is used by design professionals and hobbyists worldwide,
for creating a wide variety of graphics such as illustrations, icons, logos, diagrams, maps and web graphics. Inkscape uses the W3C open standard SVG (Scalable Vector Graphics) as its native format,
and is free and open-source software. Download and install Inkscape from https://inkscape.org/en/download/windows/ (Important: download 0.48.5 version)
Now you need to install an Add-on that enables the export images to gcode files. This add on can be found here with installation notes.
https://github.com/martymcguire/inkscape-unicorn
please follow the video on you tube how to create G-code file
some ready made G-code files
Step 7: Processing IDE Program (GCTRL)
Upload the gctrl file to processing IDE
and click on PLAY button in processing window.
first press 'p' to select you com port if you want
you can set jog speed by pressing 1,2, or 3 button
from keyboard press 'g' to load G-code file your machine is ready to plot
as soon as you hit enter by selecting g code file now you have done
your plotter is ready
thanks for your attention
