loading
this a mini CNC 2D plotter made from old DVD drive and L293D motor shield very cheap but intresting
let see how to make
It is very easy to make all the step by step procedure is mention in this instructable
Step 1: Video of CNC machine working
Lets see the video this video also cover step by step procedure how to assemble the machine
Step 2: Material need for this project
1) 2 X SCRAP DVD DRIVE
2) 1 X ARDUINO UNO R3 / ARDUINO MEGA
3) 1 X L293D MOTOR SHIELD
4) 1 X SERVO MOTOR (TOWER PRO 9G)
5) JUMPER WIRES
6) SOME HARDWARE NUT BOTS ETC
7) DOUBLE SIDE 3M TAPE
Librairy For Adafruit Shield Driver Motors extract the file and past them to arduino/libraries
Step 3: Assembling the machine
Open the scrap DVD Drive and remove internal moving tray..
This tray having stepper mechanism on it this will act as our X-axis & Y-axis.
Go through the attached pictures for understanding how to assemble your machine.
make hole on empty DVD drive case mount our X-axis and Y-axis on respective DVD case with the help of nut bolts.
Now place them perpendicular
Step 4: Wiring details
watch the picture carefully and wire components accordingly
Step 5: CNC Code for arduino
upload the code to arduino using arduino IDE
Step 6: G code
To make gcode files that are compatible with this cnc machine you have to use the Inkscape.
Inkscape is professional quality vector graphics software which runs on Windows, Mac OS X and Linux.
It is used by design professionals and hobbyists worldwide,
for creating a wide variety of graphics such as illustrations, icons, logos, diagrams, maps and web graphics. Inkscape uses the W3C open standard SVG (Scalable Vector Graphics) as its native format,
and is free and open-source software. Download and install Inkscape from https://inkscape.org/en/download/windows/ (Important: download 0.48.5 version)
Now you need to install an Add-on that enables the export images to gcode files. This add on can be found here with installation notes.
https://github.com/martymcguire/inkscape-unicorn
please follow the video on you tube how to create G-code file
some ready made G-code files
Step 7: Processing IDE program (GCTRL)
Upload the gctrl file to processing IDE
and click on PLAY button in processing window.
first press 'p' to select you com port if you want
you can set jog speed by pressing 1,2, or 3 button
from keyboard press 'g' to load G-code file your machine is ready to plot
as soon as you hit enter by selecting g code file now you have done
your plotter is ready
thanks for your attention
<p>Hi all some things I found.</p><p>In step 4 you are told to connect Y axe to M3 M4 this did not work for me I connect Y axe to M1M2.</p><p>If printed text is back to front I switched a1a2b1b2 in reverse order eg a1 becomes b2 and a2 becomes b1 and so on.</p><p>If one axe moves and the other stays still then (1) check that all wires on the axe that wont move are connected correctly or (2) you may need to switch only one pair of wires eg a1 a2 becomes a2 a1.</p><p>I have two types of images.</p><p>(1) Starts in the middle of the plot Arduino software change X and Y min max -18+18.</p><p>(2) Starts right hand side closest to me Arduino settings X Y max 36.</p><p>I hope that this might help in some way.</p><p>K</p>
<p>X Y Min Max</p>
<p>Hi , </p><p>everything work good except that it draws half of the pic of just part of it ! i'm thinking I'm not configuring the start point or inkscape properly ! would explain your point (1) &amp; (2) more please . </p><p>thanks </p>
Hi Aboudez<br>I had the same problem and I changed the min and max settings in the Arduino .ino sketch to -18 +18 and uploaded it to the Arduino.<br>I then found the center of the plot area and centered the pen here before starting.<br>There is a lot of trial and error but you will get there.<br>K
<p>O'DonovanM, I'm sorry, I accidentally deleted your post, I guess. Contact me, please. </p>
<p>Hi Berth</p><p>I was thanking you very much for all your help.</p><p>You mentioned that Inkskape started plotting in the centre and the Arduino program should be Changed the X Y min max to -18 +18.</p><p>Thanks again.</p><p>K</p><p>PS Please don't delete this one Ha Ha.</p>
<p>The Image I mentioned</p>
sumedhreddykoppula@gmail.com
<p>??</p>
<p>Thank you <a href="https://www.instructables.com/member/BertR15" rel="nofollow">BertR15</a> sir .... Guys u can watch this video ---- https://www.youtube.com/watch?v=PE8r2sd_NkA&amp;feature=youtu.be</p>
<p>Hi BertR15 <br> can you please upload your cnc.ino file so that i can compare with mine.</p><p>and i am facing problem setting my XandY steps per mm and Limits for X and Y.</p><p>please Let me know ASAP.</p><p>obviously my sketch output is insane ,I need Help. </p><p>and regarding connections to arduino i dont have clarity with them , I request you to explain me </p>
<p>Everything is already clearly explained! If you would read all previous comments it all becomes obvious!</p><p>1 - Use the arduino sketch (the ino file) made by AquaManiac.</p><p>2 - Have a look in your gcode files and look what range it will plot (-19 to +19 or 0 to 40). Adjust your limits accordingly.</p><p>3 - In Inkscape, make a little drawing of a line with a length of 25 mm and adjust the steps per mm so that the plotted line is 25 mm.</p>
<p>I am using 2 DVD stepper motors, but still, the output is not what I expected it to be.. but the motors which I am using have different pin-out for wires..? does that means they do have different steps/rev..?</p><p>The output for STAR is in the picture.</p><p>The Gcode for star and elliptical are</p><p>config i am using in the code are-</p><p>steps/rev = 20; steps/mm(x&amp;y)=360; x=(0:40) y=(0:40)</p><p>Help me out !!</p>
<p>I Have tried Everything Every Formation you Give. But Nothing goes happen. My X axis doesn't work properly But Y Axis Works Perfectly...Why..??</p><p>I Interchange Every Possible Connection But Nothing Happened.</p><p><a href="https://www.pinterest.com/pin/628111479249911041/" rel="nofollow">https://www.pinterest.com/pin/628111479249911041/</a></p><p>Please See The Video And help me with Your Opinion... <a href="https://www.instructables.com/member/BertR15" rel="nofollow">BertR15</a> ...<a href="https://www.instructables.com/member/CNC%20World" rel="nofollow">CNC World</a> ..:)<br><br>https://youtu.be/fzfBfp75e0k </p>
<p>Hi,</p><p>whether can be used two Easy Driver Stepper Motor Driver A3967 instead of the L293D MOTOR SHIELD??</p>
<p>Thanks for the great instructable. Here is the one I made. I used two L293 driver boards. Worked like a charm!</p>
<p>This was supposed to say MI</p><p>I have tried switch motor wires, I have tried changing the x and y min and max values, and I have also tried to change the stepspermillimeter but all these drawings keep coming out wrong. Can anyone help me?</p>
<p>I figured it out, My stepper motors were going to fast.</p>
<p>How did you fixed that? </p>
<p>I changed the code</p>
<p>Mine also seems really jerkey, is that normal?</p>
<p>Hello guys, i need help.<br>I have two dvd but this was different. it can be seen more clearly in the picture.<br>Can you tell which part is similar to the image A1, A2, B1, B2. so I can start to solder it.</p><p>its make me confuse all the video I saw nothing like this. i hope anyone will answer my question thank you and sry if my english so bad. i hope you answer with picture.</p>
I have made cnc plotter but its making wrong and hazy things
<p>Every things was ok but while printing any thing its not properly. I check every thing 10 times but same its not create any thing.... its only dots and some lines......plz help me........n srry for bad english.....plz help me..</p>
<p>super project. Thank you</p>
<p>Hi everybody.. Thanks for this amazing project.</p><p>I've been playing arround with AquaManiac version of both Arduino code and OSX app (thanks dude. wonderful job). </p><p>Now I have this weird problem which is that when it is printing, suddently it stops<br>with the a very hight pitch moise coming from the stepper motor. Been touching delay paramenters, but cant find the reason.. </p><p>Using AquaManiac (thanks again :)) app, when this happens, the box with the port connection resets (gets blank).</p><p>Using proccesing code, also happens.. </p><p>Any ideas what could be happenig?</p><p>Thanks</p>
<p>Hello There,<br><br>I attempted your project with one main difference : I used old scanners' stepper motors instead of DVD drivers' since they are bigger and also easier to connect the wires to since I find soldering to these small ribbon cables of the DVD drivers extremely painful. Anyway I checked all the connections, hardware seems fine so is software but when I attempt to move any of the axes (X &amp; Y) it produces some whistle noise and that's it !!! I suspected the power outlet so I changed the phone charger from your block diagram above and replaced it with a PSU and still no moves and only whistles ! Any suggestions or thoughts on what went wrong &amp; how to fix it ? Thanks in advance</p>
I made same with this instructable...<br>But the machine drawing some symbols when I inserted YouTube gcode.<br>Please help me.Tried 10 times.but same results.
<p>Hi,</p><p>it is a very interesting project.</p><p>Can one uses CD Drive instead of DVD Drive in this project?</p>
<p>probeblly yes</p>
<p>So I start to make it from 2 CD drives to give it a try.</p><p>I just don't know how to solder the four wires to the stepper motor, because here on CD Drive there is not four but five outlets on the stepper motor. Two of them is for + and - of the stepper motor. With a 5V DC I can start the motor in one direction or in another if I change + and -. But what is the other three outlets of stepper motor for?</p>
<p>From the other side this motor tray looks like on this image bellow.</p><p>So I really do not know where to solder four wires to this stepper motor?</p>
<p>I think you can</p>
I have a avr duide errer uploding the code.
It is very nice and cool..
<p>how to fig it... it not move....</p>
<p>wrong com port selected</p>
<p>u have to close other Arduino window or gctrl window and add yr Arduino drive also select the right port ... then upload yr program.. </p>
<p>Try this G code ...</p>
<p>please help .... my X axis stepper is not working .... :(</p>
<p>Made this over Christmas. And have it working nicely! Thanks CNC World.</p><p>Have written an OSX app to feed the GCode rather than using processing (has other features too) and updated Arduino code for auto home. Will be making these publicly available shortly.</p><p>BTW - Agree 100% with BertR15 - you NEED a solid pen holder for good results.</p>
<p>nice job aquamaniac</p>
<p>Very nice!</p><p> I'm very interested in the Arduino code for auto home but also the OSX app.</p><p>Hope to see it soon.</p><p>Grtz</p><p>Bert</p>
<p>Both the Arduino changes and the OSX App are now available.</p><p>Check out: </p><p><a href="https://github.com/AndyQ/CNCPlotter-Arduino" rel="nofollow">https://github.com/AndyQ/CNCPlotter-Arduino </a> - Ardiono sketch</p><p><a href="https://github.com/AndyQ/CNCPlotter" rel="nofollow">https://github.com/AndyQ/CNCPlotter </a> - OSX App</p><p>Unfortunately at this time you will need to manually build the OSX App. I'l try to get a developer signed build out at some point.</p><p>Andy</p>
<p>Hi All,</p><p>First of all, this is not my 'instructable'! It is writen by <a href="https://www.instructables.com/member/CNC%20World" rel="nofollow">CNC World</a>. He did a great job because even I could make this nice machine!!</p><p> Now, a lot of people asked me how I did this or how I did that, but it all comes down to a few things:</p><p>1. Work precise. If you make a sloppy pen holder, your plot will come out sloppy!</p><p>2. If it is not working out of the box, fiddle around! Be creative! Change a few settings, one by one, and look what happens! </p><p>3. The plotting area is 38 x 38 mm. Try to make your drawing well within these limits. In Inkscape, don't go all the way to the edges.</p><p>4. Don't give up! The master has failed more times than the beginner has even tried.</p><p>I have added a few pictures to show the possibilities and precision. If you want the G-code, let me know. There is only one condition for that: you post <strong><em>your plot</em> </strong>of that G-code :-)</p><p>Grtz</p><p>Bert </p>
<p>Thanks for sharing your experience BertR15</p>
<p>Sir my dream is working .I have changed the pen holder then it's working properly..tnx sir... bt one think, some codes doesn't work properly .. why sir? </p>
<p>I don't know why some code is not working properly. Try to run it in CAMotics. Maybe the code itself is not okay.</p>
<p>I have also seen your second project which I would call 'next level'.</p><p>When assembling the hardware, I am stuck at a point where I wanted to test my motors for basic operation. My issue: What / which code + library do I need to use if I have a 'sunfounder' shield instead of Adafruit?</p><p>An early response will be highly appreciated!</p>
<p>sorry for late replay </p><p>yes you can go with AFmotor library with sunfounder shield</p>
About This Instructable
96,012views
929favorites
License:
Bio: Science lover
More by CNC World:DIY Arduino based Mini CNC machine new Design How to Make Arduino Based Mini CNC Plotter Using DVD Drive
Add instructable to:
