If you like this instructable, Digg it!
Then check out episodes one, two, three, four, five, and
seven!
Remove these ads by
Signing UpStep 1Find Bacon Fat
You can render your own bacon fat by just cooking bacon - I would cook up at least 10 pounds of bacon if you want to render enough fat to make a sizable batch of soap (my one liter of fat came from around 10 pounds of bacon and yielded about a dozen bacon soap strips and about another dozen small to medium sized bars. You can cook less bacon if you want to make less soap.
The fattier the bacon you buy for this the better results you will have. Also, cooking it on the stove in a pan is going to be the way to go here - don't try any microwave tricks, you won't render nearly as much fat. Don't worry if lots of black and brown bacon bits get into your rendered fat, they can be purified out later.
You can also buy lard directly at the grocery store - although something about just buying the lard without the bacon seemed to be like cheating when doing something as epic as turning bacon into soap, but if you want to save some time and money - buying the lard direct would be the way to go.
***Note: I have found that a good way to clean dirty bacon fry pans is to pour old coffee grounds into the pan (this was taught to me on the river), let it sit for a bout half an hour and then do some scrubbing. The blackened crud on the bottom of the pan comes off much easier this way than if you try to attack it head on.***
If you're going to be saving your bacon fat over any length of time, get yourself a nice big plastic or glass jar. Remember to let the fat cool a little before pouring it into your container so you don't crack or melt it.
BUT To marble your soap use a toothpick. I think a longer, plastic implement might be better, like a plastic fork with 2 tines removed. Lay down a thin layer of red, then a thin layer of white and have a friend drag the fork though the soap longways. Dont lift the fork out till you get to the end, then left straight out and start again at the beginning. doing this 2-3 times should give you a good effect.
http://waltonfeed.com/blog/show/article_id/165
I MADE MAH SELF!
may have to try this sometime though! I just don't know when I'll have enough bacon to waste to do it. Would it also work to buy a tub of lard and use that?
It's a perfectly good excuse to cook and eat enormous amounts of bacon!
WHY WAS THERE BACON IN THE SOAP!!!
to create more realistically-marbled soap, it might work if you think of painting the white streaks onto both sides of the strip of soap, as opposed to having bacon that's actually marbled in cross-section. kind of like the technique used to paint the mold when making multicoloured chocolates.
maybe you could streak the mold with a little bit of white soap drizzled from a spoon. make "fat stripes", but leave gaps. let it harden a bit. then pour red soap to fill the whole mold with "meat"- the red will show red through the gaps you left when you applied the white streaks. let it harden a bit. lastly, take a bit more white and streak the top side of the bacon with "fat".
not sure how fast the soap hardens, so this may not be practical- maybe making plain red strips, then unmolding them and painting white on them by hand is the way to go. either way, i think the key lies in making the fat streaks superficially.
pour two or three frosting bags at the same time
Narrator: Wait. What is this place?
Tyler Durden: A liposuction clinic.
