3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Make Bacon Soap
Step 1Find Bacon Fat
Find Bacon Fat
You can get bacon fat from a variety of sources. I got my bacon fat from working as a white water rafting guide over the summer. Day three of a five day rafting trip means bacon for breakfast, lots of it. I collected the rendered fat in plastic water bottles with the original intention of using the grease to make a bacon fat bomb - basically a concentrated grease fire, but what didn't get used to make grease bombs followed me home and sat on the shelf for a while. After cooking bacon a few times in my house, I had a little more than a quart of rendered bacon fat ready to go.
You can render your own bacon fat by just cooking bacon - I would cook up at least 10 pounds of bacon if you want to render enough fat to make a sizable batch of soap (my one liter of fat came from around 10 pounds of bacon and yielded about a dozen bacon soap strips and about another dozen small to medium sized bars. You can cook less bacon if you want to make less soap.
The fattier the bacon you buy for this the better results you will have. Also, cooking it on the stove in a pan is going to be the way to go here - don't try any microwave tricks, you won't render nearly as much fat. Don't worry if lots of black and brown bacon bits get into your rendered fat, they can be purified out later.
You can also buy lard directly at the grocery store - although something about just buying the lard without the bacon seemed to be like cheating when doing something as epic as turning bacon into soap, but if you want to save some time and money - buying the lard direct would be the way to go.
***Note: I have found that a good way to clean dirty bacon fry pans is to pour old coffee grounds into the pan (this was taught to me on the river), let it sit for a bout half an hour and then do some scrubbing. The blackened crud on the bottom of the pan comes off much easier this way than if you try to attack it head on.***
If you're going to be saving your bacon fat over any length of time, get yourself a nice big plastic or glass jar. Remember to let the fat cool a little before pouring it into your container so you don't crack or melt it.
2 comments
Nov 12, 2008. 7:12 AMEvil_Steve says:
A Great way to render bacon fat without cooking it off and making a messy pan is to use the oven. Just use a sheet pan and a cooling rack. Put the cooling rack in the sheet pan and place the bacon on the rack. Set your oven to 400 and put the bacon in. The fat drains down into the pan and you get perfectly crisp bacon, and since the fat isn't in direct heat from the burner, it doesn't burn off.
Aug 30, 2010. 3:07 PMfirefly68 says:
I also cook bacon in the oven in a sheet pan; but I like soft bacon, not crisp, so I don't use a rack. Either way is a GREAT way to make bacon for a crowd; or cook a pound till it's almost done, and then nuke a couple pieces when you want to eat them. (Wrap in a paper towel and nuke ~10 seconds.) I line the pan with tin foil and spray with Pam--no cleanup! And I can save the fat if I want to. Not sure I'd want to make soap out of it...but then again it might be a great way to attract men! ;-)
Feb 13, 2007. 5:05 PMmohnkern says:
Another good way to collect the fat is a old soup can washed out well. It's got the advantage of not having problems with hot fat, you can pour it right in. Keep a tinfoil top on it to prevent it from getting more yucky.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
881
Author:noahw
Editor of the Workshop and Outside channels...I'm back!
