Step 7Pouring Into the Molds
We first filled each bacon mold about half way with the white soap. Then we went back and filled in the rest with the red. I used a spoon to try and mix the two colors together a bit in an attempt to make it look like strips of bacon meat and fat. This only sort of worked. I'd love suggestions of how to get more accurate marbling of the bacon if anyone has any ideas.
With the bacon molds filled and still plenty of soap left over in the plastic bowl, we poured off some of the white soap mixture and turned it yellow with dye. Mike and I then poured that mixture into the yolk section of the plastic egg molds and then filled in with white on top of that. This actually created a pretty nice fried egg!
When we still had even more soap left over from that I poured it into an ice cube tray to make some travel bars.
BUT To marble your soap use a toothpick. I think a longer, plastic implement might be better, like a plastic fork with 2 tines removed. Lay down a thin layer of red, then a thin layer of white and have a friend drag the fork though the soap longways. Dont lift the fork out till you get to the end, then left straight out and start again at the beginning. doing this 2-3 times should give you a good effect.
to create more realistically-marbled soap, it might work if you think of painting the white streaks onto both sides of the strip of soap, as opposed to having bacon that's actually marbled in cross-section. kind of like the technique used to paint the mold when making multicoloured chocolates.
maybe you could streak the mold with a little bit of white soap drizzled from a spoon. make "fat stripes", but leave gaps. let it harden a bit. then pour red soap to fill the whole mold with "meat"- the red will show red through the gaps you left when you applied the white streaks. let it harden a bit. lastly, take a bit more white and streak the top side of the bacon with "fat".
not sure how fast the soap hardens, so this may not be practical- maybe making plain red strips, then unmolding them and painting white on them by hand is the way to go. either way, i think the key lies in making the fat streaks superficially.
pour two or three frosting bags at the same time
