3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Make Ballistic Gel : The 15 minute Way
If there is one important material for evil geniuses, it's ballistic gel. This gel is the perfect copy of human flesh. It has the exact same weight, resistance, everything. Its easy to make, can be made in 45 minutes (counting refrigeration), and is great for testing guns. Ballistic gel is 100% gelatin, the same white stuff used for candy. Myth busters use this often for gun shoot tests. This isn't the myth busters recipe but an easier version.
Step 1What You Need
What You Need
 You need almost nothing for this project :
-sheets of gelatin x8
-small spoon x1
-scissors x1
-cup x1
You can't see my gelatin but in the bottom center .
9 comments
Jul 5, 2011. 8:39 AMneodymium says:
it is not ballistic gel yet. you have to melt it after being in the fridge (which by the way you have to refrigerate it for 3 hours, not 30 minutes. then you have to put it back in the fridge for 24 hours to bloom. look up what blooming is with ballistic gel if you do not know what it is.
this way of making it is totally off. try making it the right way and your way then compare them to see what i mean.
Jul 5, 2011. 8:42 AMneodymium says:
p.s. you also have to use knox unflavored gelatin mix. the ratio is 1oz mix per 1 cup water.
Apr 30, 2010. 12:14 PMjtobako says:
Ballistic gel is nice, but what about imitation bone-like a rib or skull?
May 1, 2010. 1:16 PMfirefletcher says:
 They do that on myth-busters by actually casting the ballistics gel around a human skeleton.
Aug 27, 2010. 9:08 PMbeehard44 says:
they use it to shoot random sh** at and record the depth of entry. e.g. cigarettes, bullets, ice bullets and stuff like that.
Jan 30, 2012. 8:12 PMihaveguitarskills! says:
Probably just one of those skeletons they use in science classes. That's what I would do.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:Quest for Questions
My goal is to be the person with the most questions.
