Introduction: How to Make Beaded Flower Earrings Tutorial With Simple Beading Techniques
Wonder how to make beaded earrings tutorial? Please check out this tutorial, which is totally about beaded flower earring patterns.
Step 1: Materials Needed on How to Make Beaded Earrings Tutorial:
Step 2: Make the Dangle for the Beaded Flower Earrings Patterns
1st, cut off about 70cm tiger wire, slide 3 seed beads onto the middle of wire, thread both wires to a drop glass bead;
2nd, add 4 seed beads to each wire again, cross both wires to an abacus glass bead and tighten wires.
Step 3: Make the First Beaded Flower for the Earrings
1st, slide a seed bead and an abacus bead onto one wire, add 5 seed beads to the wire again, pass the wire back to the abacus glass bead and tighten wires;
Step 4:
2nd, add a seed bead and an abacus bead again, and then repeat process 3rd one time;
Step 5:
3rd, repeat process 3rd and 4th to make the other wire as the same;
Step 6:
4th, add a seed bead onto each wire, and cross both wires to an abacus glass bead and tighten wires;
5th, add 2 seed beads onto each wire again, cross both wires to a seed bead and tighten wires.
Step 7: Make the Second Beaded Flower for the Earrings
1st, add a seed bead to each wire, cross both wires to a seed bead and tighten wires;
2nd, add 2 seed bead onto each wire again, cross both wires to an abacus glass bead and tighten wires;
Step 8:
3rd, make the second flower in the same method.
Step 9: Finish the Beaded Flower Earrings Patterns
1st, slide 2 seed beads onto each wire, cross both wires to another seed bead and tighten wires;
Step 10:
2nd, conceal the wires by passing the beading path;
3rd, attach an earring hook to the beaded flower.
Step 11: The Final Look of Beaded Flower Earring Patterns Is Like This:
So far, the beaded flower earrings patterns are done! They are so simple but beautiful, are they? Now, you must have known how to make beaded earrings tutorial! Just make a unique pair of beaded flower earrings for your own or send to your close friends.
