Introduction: How to Make Bi-Directional Flex Sensors
Applications
Flex sensors may be used in robotics to determine joint movement or placement. They may also be used like whiskers for wall detection. The sensors we are making are also pressure sensitive so they can also be used as bumper switches for wall detection or pressure switches on robotic grippers. For bio-metrics, the sensor can be placed on a moving joint of athletic equipment to provide an electrical indication of movement or placement. A few of the sensors can be incorporated onto a glove to make virtual reality glove.
Step 1: Components:
The materials needed for the construction of the bi-direction flex sensor is shown in figure 1 and listed below. The size of the materials listed is only a guideline to the sensor we are constructing in this article. These types of sensors can be manufactured to larger widths and lengths.
1. Copper foil laminate 1/4" x 4.5" (see text)
2. Acetate 1/4" x 4.5" x .010 thick
3. Heat shrink tubing 3/8" dia x 5"
4. Resistive material 5/16" x 5" (see text)
Copper foil laminate is used in the electronics industry to make flexible circuits. It is thin copper cladding on a plastic material substrate like acetate. The material we are using is single sided copper. Copper on one side and the substrate (plastic) on the other, The copper cladding material is cut into two pieces 1/4" wide x 4.5" long strips. The material is easily cut with a scissors. Solder about 6" of wire to one end of each strip. You may fine it easier to solder the wire to the strip if you tin the bottom 3/8" of each strip. Solder each wire to one corner side of the strip. It doesnt matter which side you choose, just make sure you solder both strips on the same side, see figure 2.
Resistive Materials
There are a variety of resistive materials available; cloth, plastic and paper. The common element of all the appropriate materials is that the material is somewhat conductive or resistive. The degree to which the material is resistive will determine the scale at which your flex sensor operates. For the example here I am constructing here, I using conductive black plastic poly bags conductive bags used in the electrical industry. These bags are used to store components that are static sensitive. The bags are made from single layer of carbon-loaded polyethylene and its conductivity does not depend on humidity. I cut the bags into the 3/8 " wide by 5" long strips.
Step 2: Making the Bi-Directional Flex Sensor: (Sandwich the Materials)
The resistive material is sandwiched between the two copper clad laminates. The copper sides of the laminates are both facing toward the resistive material; see figures 3, 4 and 5. If you soldered the wires on the same side of the laminates, when you assemble the sensor, the wires will be positioned on opposite corners allowing the base of the sensor to lay flatter.
To this sandwich we add the acetate strip, see figure 6. The purpose of the acetate strip is to make the sensor more resilient and to spring back after it has been flexed.
Step 3: Packing the Sandwich
Step 4: Sealing the Sensor
Step 5: Testing the Bi-Directional Flex Sensor:
Set a VOM meter to read ohms. The sensor we built had a nominal resistance of approximately 20K ohms, see figure 10. As the sensor is bent in one direction Figure 12the resistance decrease in proportion to the bend to approximately 2k, see figure 11. Bending the sensor in the opposite direction also decreases the resistance in proportion to the bend to 2K ohm, see figure 12.
The sensor is also pressure and force sensitive. So pressing down on the sensor will also decrease it resistance. The basic sensor can be modified in size and shape to fit custom applications. The resistive material may also be modified to obtain different resistances and characteristics. Most materials are easily obtained from electronic sources. Images will supply the following materials to get you started.
