3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Make Bi-Directional Flex Sensors
Step 5Testing the Bi-Directional Flex Sensor:
Set a VOM meter to read ohms. The sensor we built had a nominal resistance of approximately 20K ohms, see figure 10. As the sensor is bent in one direction Figure 12the resistance decrease in proportion to the bend to approximately 2k, see figure 11. Bending the sensor in the opposite direction also decreases the resistance in proportion to the bend to 2K ohm, see figure 12.
The sensor is also pressure and force sensitive. So pressing down on the sensor will also decrease it resistance. The basic sensor can be modified in size and shape to fit custom applications. The resistive material may also be modified to obtain different resistances and characteristics. Most materials are easily obtained from electronic sources. Images will supply the following materials to get you started.
You can purchase Flex Sensor Components from Images Scientific Instruments:
http://www.imagesco.com/sensors/flex-sensor.html#comp
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
16
Author:jiovine
