Introduction: How to Make Blacksmith Tongs
Picture of How to Make Blacksmith Tongs
Hello!
Today I’m going to tell you how to make a hand-made blacksmith tongs
Neither blacksmith does anything without tongs also without an anvil, a forge with a burner (all of them are in my profile on instructables) and other tools which made by blacksmith hands.
Tongs are different and I’m going to tell you about the most convenient one. Of course, it’s my subjective opinion about convenience and the reason why I consider so is that the tongs are big enough to hold small and big workpieces and they have round lips to hold armature easily also they are wide enough to hold flat details.
We don’t need special tools, but some preparation is necessary.
The necessary tools:
-an angle grinder
-a drill
- a forge
- an anvil
The necessary materials:
-round armature. Diameter 12 mm, length 500 mm, 2 pieces
-a bolt (rivet)
I’m explaining now why I chose such materials. It doesn’t make sense to take armature with fewer diameters because it’ll be mild and impractical. It’ll be even better to take bigger diameter but in this case we have to make efforts for forging and warm-up of workpieces in general. So 12 mm are enough for working in a garage. Length is also for convenience – if it’s longer it’ll be hard to hold a workpiece with tongs; if it’s shorter you’ll be able to burn yourself during the process. And it’s better to take longer because you’ll always be able to cut it off. You can choose a bolt with the same principle- shorter one will be unreliable, longer one will have thin sides in a place for drilling.
Generally, all work is demonstrated in my video so I’m briefly telling you the process.
Step 1: Working With Tongs Lips
Picture of Working With Tongs Lips
As I’m doing a cross functional big tongs I’m spreading armature on 100mm. If you have difficulty in seeing the size you can use a ruler. One of the most convenient variants of a ruler for forging I showed in my video about the anvil.
Step 2: Spreading a Place
Picture of Spreading a Place
Turning over the workpiece on 90 degrees we’re beginning to spread a place for two sides conection of the tongs.
Step 3: Making a Shape
Picture of Making a Shape
I decided to bend them in a vice because my stump was unsteady. It turned out to be fast and easy.
Step 4: Making the Tongs Lips Better
Picture of Making the Tongs Lips Better
Now our tongs have had their final look and someone can stop at this stage, but I decided to make the tongs lips better and welded some pieces of wire to the ready-made tongs.
Step 5: Drilling a Hole and Fastening a Bolt
Picture of Drilling a Hole and Fastening a Bolt
It’s left to drill a hole and to fasten a bolt in the tongs. As it’ll hardly be necessary to spin the connection up I welded a crew. The result is such a semi-screw.
And now you can see all described things in my video.
shapespeare (author)2017-03-19
Good tutorial. Very nice design. But you are a blacksmith, you should punch the hole not drill it!
BonnF (author)shapespeare2017-03-21
Thx, you are talking right! But EpicElrod is right too. It's a tutorial for beginners- the easier the better
EpicElrod (author)shapespeare2017-03-19
Punching a hole is a lot of work, and it upsets the metal a little bit. It is much more difficult to punch throught the hole. Also, most people could more easily drill a hole than punch it.
About This Instructable
3,718views
82favorites
License:
Bio: I make art metal works and some useful tools
More by BonnF:How to make a metal rose without welding and forgingMetal Etching - How to Make a Man's Visiting CardHow to Make Blacksmith Tongs
Add instructable to:
