How to Make Blue Flames
Published
Introduction: How to Make Blue Flames
About: I build stuff because it isn't available to buy, or is too expensive, or the ones you can buy don't do what I want them to. Sometimes I don't have a reason, I just want to build something. For me it's about...
I wanted to make Red, Blue, and Green flames for my fire breathing dragon mask. This is how I did the Blue.
Links to related projects:
Red Fire: https://www.instructables.com/id/How-to-Make-Red-F...
Green Fire: https://www.instructables.com/id/How-to-Make-Green...
Fire Breathing Dragon Mask: https://www.instructables.com/id/How-to-Build-a-Fi...
Step 1: Materials Required
  1. Methanol
  2. Copper Sulphate (or Copper Chloride II)
  3. Hydrochloric Acid
You must use Methanol, or ethanol, because they burn with an invisible flame. If you use another fuel, they usually burn yellow, and will not give as clear and vivid colours.
Methanol is adsorbed through the skin. It damages the liver, and if you ingest 50ml or so, you can suffer from blindness which could be permanent. A cure for methanol poisoning is ethanol. But it's best to give your liver a rest and avoid the methanol in the first place.
Copper sulphate is corrosive, as is Hydrochloric acid.
Step 2: Mixing Them Together
A stir plate isn't necessary, but an erlenmeyer flask and a stir bar will make life easier on you. I'd suggest a 500ml flask, My 1L is too big really. 250ml is probably too small for this: https://www.amazon.co.uk/Academy-Measuring-Molecu...
Stir bars are pretty cheap:https://www.amazon.co.uk/AJSR-magnetic-stirrer-mix...
You can easily make one out of a pc fan and two magnets.Instructions on how to make a stir plate:https://www.instructables.com/id/Stir-Plate-From-Co...
There are plenty of other instructables on this too. I might do my own at some point.
First mix the Copper sulphate and Hydrochloric acid until it's dissolved, then add that to the methanol. you want a solid >70% methanol to ensure flammability.
Step 3: Test It Out
Burn it, just do it in a well ventilated space. Don't breath in the fumes. Wear PPE as necessary. Follow the MSDS for the chemicals you buy.
  • You can burn it in an empty can.
  • Or use a spray bottle to spray it.
  • Or even use a fuel injector off a car, though this will break it in my experience.
    • Clocks Contest
      Clocks Contest
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
