Many thanks to Instructables user Argon for coming up with this idea and giving me necessary tips on how to make it.
**Warning, dry ice is cold to the touch and can hurt you if used inappropriately. Please exercise caution when working with it, wear proper safety protection, and use it responsibly.**
Now on Know How! Click on the steps above for more details.
Do you like this Instructable? Digg it!. Then check episodes one, two, three, five, six, and
seven!
Remove these ads by
Signing UpStep 1Materials
Fruit
When making carbonated fruit it's best to use firm fruits, like oranges, apples and pears. I tried doing it with softer fruits like kiwis, strawberries and bananas and it just doesn't work as well. Apples in particular seem to work the best.
Bottle or Container
You will need a plastic bottle or a container to put the fruit into. I have found that a wide mouth Nalgene works best. You can use an empty 2 liter soda bottle however, just be careful not to add in too much dry ice, more on that later. DO NOT use a glass jar. The bottle will be under pressure and broken plastic is safer than broken glass. If you have a vessel that is designed to take pressure, like a beer keg for example, than by all means try using that.
Dry Ice
The final thing you will need is a block of dry ice. You will only need a tiny tiny amount of dry ice to make the carbonated fruit, but its hard to buy less than a large block of the stuff. Now, chances are that you have never seen dry ice for sale. You can't make it on your own and you might not be able to find so easily.
I used the Dry Ice Directory to find out where it was being sold locally - they have listings for all over the world. I live in the east bay of California. I was surprised that In all of Oakland there was only one distributor - the AM PM Gas Station on Market and Grand in West Oakland. They oddly enough had a ton of the stuff for sale, and they are open 24/7! I was very impressed that I could buy dry ice anytime I wanted even if it was only for sale at that one place.
**Before you go to buy the dry ice please refer to this
Dry Ice Safety Info website. I am not going to go through all of the safety precautions that should be taken in this instructable, so take a minute to familiarize yourself with its possible safety hazards.**
The more dry ice you use the less likely you want an 'air-tight" seal (as to prevent overpressure). I suppose you could use a pressure relief valve too (to prevent exploding) - head over to McMaster-Carr (www.mcmaster.com) and you should be able to find a slew of pressure relief valves, this of course require some mods to your "container", but definitely reduces the exploding factor.
What the first post describes is a process called 'raking' you remove the stem from the grapes and place them in a barrel, vat etc and using a small rake you move the grapes around three or four times during a 24 - 36 hour period. this opens up the grapes and kind of gets them acclimated, 'not really sure what it does it is tradition. Then you would press them in a grape press and add yeast to the juice and store them in a barrel. But, that is more info than needed and you should see 'making wine' on Instructables.
get water...fruit juice whatever
add dry ice (quite a bit compared to what they put in)
let it bubble away until there's no dry ice left (stir occasionally or heat water before so that it doesn't freeze the water.
drink it
swallow it
go to the bathroom
lol
Devices rated for hundreds of psi must go by another name.
By contrast, an ordinary soda bottle is rated for 100 - 120 psi. The pressure relief mechanism (the cap popping off) is unreliable at these pressurization speeds, though.
