How to Make Clear Slime (Liquid Glass)
Published
Introduction: How to Make Clear Slime (Liquid Glass)
This tutorial show you how to make Clear slime with Borax and Glue
Step 1: Materials:
Material:
Elmer clear glue
Borax
2 x A bowl
Something to mix (a spoon)
Water
Step 2: Step 1: Make Borax Mixture
Add 1 cup of water to bowl #1
Add 1 teaspoon of Borax into water and mix
I use warm water
Step 3: Step 2: Make Glue Mixture
Add 1/2 cup of clear glue into bowl #2
Add 1/2 cup of water into glue
Mix
Step 4: Step 3: Put It Together
Add Borax mixture into Glue
Use your hand to mix
It should form instantly
You can stretched, make a ball and bounce around
Step 5: Step 4: Store the Slime
To keep the slime from dry out, put in zip lock bag
Have fun making it. :D
Please subscribe to my Youtube channel: https://www.youtube.com/c/RiceDummy8?sub_confirma...
2 People Made This Project!
  • Pets Challenge
    Pets Challenge
  • Woodworking Contest
    Woodworking Contest
  • Stick It! Contest
    Stick It! Contest
need the slime to form in 3 days
15 Comments
Mine did not work. I do not know if I simply made a mistake or the recipe had a fault, but mine turned out like the fat of a steak. Whenever I tried to stretch it, it just fell apart! I tried to add more glue but it would not work! I would not make this again and I would not recommend using this recipe.
I made this but the slime isn't clear I did your recipe and it's like kinda clear but not, it's like dirty glass.
you have to let it sit for 5-7 days
You need to let it sit in a airtight container for a few days. It'll clear up
mine didn't work either
Thanks i needed this for my egypt project .gracias
If you have a vacuum chamber, you can make it in 30 min to an hour by de-gassing it.
you have to leave the slime in the container for 5-7 days without playing with it for it to be clear. Just a heads up!
yes because pva glue is really the "only" glue you can use to make slime. But there are different methods;)
Yes, you can use PVA glue, it is the same as Elmers Clear Glue.
You have to let the slime sit for three days to get the bubbles out(ps.i did make it but i dont want to put a picture in it )
Thanks for this I am gonna use this recipe to make slim once I have all my items with me
