How to Make Crystal Snowflake Earrings With Clear Step-by-Step Pictures
1,380
67
Posted
Introduction: How to Make Crystal Snowflake Earrings With Clear Step-by-Step Pictures
In this tutorial, you will learn to make snowflake hoop earring with crytal beads. Soon winter comes, the world is getting cold and white. Adorn yourself with this fascinating appearance of tiny snowflake crystals earrings and join the awesome fairytale winterland.
Step 1: Material for Making Crystal Snowflake Earrings:
1pc. of memory wire10pcs.
AB color facetted clear glass beads
2x approx. 300cm brass wire platin color
12pcs. frosted glass beads, turqouise
2pcs. jumprings, platin color
2pcs. earring hooks, platin color
side cutting plier
flat nose plier
round nose plier
Step 2: Making Crystal Snowflake Pendant
1st, take the side cutting plier and cut one piece off the memory wire. The ends of the wire should overlap about 1 cm;
2nd, make a loop with the round nose plier on one end of the memory wire;
3rd, string one turqoise and one clear glass bead alternating on the wire. Use 6 turqouise and 5 clear ones;
4th,form an eye on the other end of the memory wire. The two eyes should overlap now.
Step 3: Wrapping the Brass Wire
1st, double-tie one piece of the brass wire next to one of the eyes you’ve formed;
2nd, now start wrapping the brass wire as shown on the picture. Four times between every two beads.
Step 4: Adding Jumpring and Hook
1st, go on in circle and create a star-looking wire wrapping. Every spacing should be used twice. When every spacing is filled tie the end to a place where it can’t be seen;
2nd, now add a jumpring with an earring hook on it to every pendant you’ve made to finish the earrings.
Step 5:
Well done! Your Crystal Snowflakes earrings are finished which will reflect the sun like the wonderful snow does. Sparkle, shine and have fun in the winter wonderland.
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
  • Gluten Free Challenge
3 Comments
so wonderful wow
