Introduction: How to Make EMP Gun !
Hello my dear friends. EMP is one of the most popularly used sci-fi gadget in movies. It is not only a science fiction concept it is real and you can make it from very common household items. So today I am going to show you. EMP gun .
EMP device stands for electromagnetic pulseEMP devices can damage any electronic devices or disturbed there working. Please be careful while making this EMP Gun. Also make sure that use of EMP is illegal in some areas. I am making this device for pure educational purposes to know the effect of EMP on day to day consumer electronics. Please do not use for destructive uses i will be not responsible for any damage.
See This EMP Gun In Action !
Step 1: How It Works !
This EMP Gun works on the principle of Electromagnetism EMP devices use high voltage generator that will convert 3.7 volt into few thousand volts voltage is further amplified through an passive voltage multipliers then it passed to a electromagnetic coil with the help of spark gap This coil that will produce high frequency electromagnetic pulses. it is possible to increase the range an the output power.with the use of capacitor connected to a coil will increase the power output of an emp. You can see in my demonstration i showed Watch , stopwatch,RFID tag,memory cards nothing got survived .
The Intensity magnetic field created by EMP gun get Induced into the circuitry of this electronic devices which basically induces the voltages all over the circuit. So you will never know what will happen. Either the device memory will reset. or It will permanently damage this device. So be careful. Keep your electronic devices far away !
Step 2: Things You Will Need !
★☆★ Buy Parts from your online local store ★☆★
1) Bug Zapper Racket http://geni.us/552R
2) Toy Gun http://geni.us/QXgl5
3) Tactile Button http://geni.us/DOLA
4) Soldering Iron http://geni.us/O7W1S
5) Wire http://geni.us/F0Bdx
Material You Will Need
1. A Bug Zapper Racket , usually used to kill mosquito's , We wiill use its high voltage generator.
2. You Will Need half meters of 1sqmm thick piece of insulated wire to make an coil , alternately if you want more range out of it you can use enameled copper wire and as many turns you want .
Tools...
1. A Soldering Iron
2. soldering Wire
3. Bit of a time with patience ! Please Wait For The gif's to load in this instructables !
Step 3: Let's Make EMP Gun !
1.OK friends so start by taking apart your bug zapper racket using your screwdriver ,inside you will find. a high voltage generator circuit.We are going to use this high voltage generator circuit along with the battery.
2. Now take 1 sq mm wire. Make a coil as shown in the picture
3.In my design I removed the output capacitor to limit the output power ! but you can Keep the capacitor as it is.
4. Solder one output wire of coil to High Voltage generator and form of spark gap using other output wire as shown in the picture above. you may need to fix the wire at a distance , Keep in mind that this gap decides output Frequency of your EMP gun closer to wires are higher the frequency will be and vice-versa so you may need to tweak the distance In between them ,I found that to 1 millimeters distance work best for me.
5. OK To make a Handle for EMP Gun I am going to use my old Toy Gun as a handle and Stick all the parts together with bit of a hot glue .
6. I also extended the push button switch so i can use it as a real EMP Gun !
Step 4: Please Do Not...
Please Do Not... point the gun at anything , it can cause real and permanent damage .
Instead You can Watch me testing this gun . be safe and act safe have a good learning !
I Guarantee you like these projects also
# DIY How To Make EMP Gun !
# How To Make USB Killer
You can Meet me at
# YouTube https://www.youtube.com/user/kedar123456889
# Facebook https://www.facebook.com/KedardNimbalkar
# Twitter https://www.facebook.com/KedardNimbalkar
