loading
Have you seen butterfly brooch before? If not, you can pay more attention on today’s Pandahall tutorial about how to make elegant pearl and drop glass beads butterfly brooch.
Step 1: Materials and Tools Needed for This Elegant Pearl and Drop Glass Beads Butterfly Brooch:
11x8mm Mixed Colored Drop Glass Beads
11x8mm CoconutBrown Electroplate Glass Beads
4mm White Glass Pearl Beads
6mm Violet Bicone Glass Beads
4mm Black Glass Seed Beads
6x1.8mm Silver Glass Bugle Beads
WhiteSmoke Square Felt
Flat Round Cabochon Brooch Settings
0.3mm Silver Copper Jewelry Wire
Scissors
Glue Gun
Step 2: Make the First Part of the Beaded Butterfly Brooch
1st, cut off a piece of 0.3mm jewelry wire and add a 4mm white pearl bead onto the wire, then slide another pearl bead onto the both wires;
2nd, slide two 4mm pearl bead onto two wires, then add a pearl bead onto both wires;
3rd, cross a pearl bead through two wires, then slide nine pearl beads onto two wires respectively and cross a pearl bead through two wires at the end;
4th, thread the two wires through two side pearl beads, then add a 6mm silver bugle bead, a 11x8mm blue drop glass bead onto both wires;
5th, thread two wires through pearl beads and fix the pattern, then cut off the extra wire.
Step 3: Make the Second Part of the Beaded Butterfly Brooch
1st, cut off another piece of jewelry wire, then thread the wire through two pearl beads (as shown in the picture);
2nd, slide eleven pearl beads onto two wires respectively, then cross two wires through another pearl bead.
Step 4: Make the Third Part of the Beaded Butterfly Brooch
1st, slide pearl beads onto a piece of 0.5mm jewelry wire and make the same pattern as made in step 1;
2nd, slide a blue drop glass bead onto two wires, then thread the wires through two above pearl beads;
3rd, attach the two pearl beaded patterns together by twisting the wires, then make another two same beaded patterns in the same ways;4th, twist all the wires together and cut off extra wires (as shown in the picture).
Step 5: Make the Four Part of the Beaded Butterfly Brooch
1st, slide two 6mm violet glass beads and a brown 11x8mm drop glass bead onto two wires;
2nd, slide three bugle beads and a 4mm black seed bead onto two wires respectively, then thread the wire through these beads and tighten the part.
Step 6: Finish This Beaded Butterfly Brooch
1st, cut off a circular piece of whitesmoke felt into the same size with the flat brooch setting, then glue the felt onto the setting;
2nd, glue the brooch setting onto the back of the beaded butterfly pattern.
Step 7: Now, This Pearl and Drop Glass Beads Butterfly Brooch Has Been Finished:
See, how do you think of this lovely pearl butterfly brooch? Are you going to give it a shot? You know that there are many beaded brooches in our website and it is the first time that we share you a butterfly brooch. So do not miss this chance if you are attracted by this elegant design.
<p>This is amazing. I love beads projects. Wonderful. Thanks for sharing.</p>
About This Instructable
1,072views
16favorites
License:
Bio: Hi, guys!! I’m Daisy. I love putting beads together to make jewelry work; sharing jewelry designs. If you like jewelry and beads, you are ... More »
More by DasiyD:Easy Bracelet Tutorial – How to Make a Wire Wrapped Bracelet With Crackle Glass Bead Decorated PandaHall Tutorial on How to Make a Chic Seed Bead Choker Necklace Easy Necklace Design – How to Make a 2-Strand Flower Bead Tassel Necklace
Add instructable to:
