3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Make Fireworks
There are many types of fireworks, where one of the most common in firework displays is the aerial shell. The aerial shell is used in fireworks displays, and can be either a round or a cylindrical shape. These aerial shells are loaded into tubes, called "mortars." Once lit, the aerial shell will fly into the air and once the aerial shell is at the higest point (apogee), it will explode and shoot pyrotechnic stars in all directions.
In this instructable I will be talking about the procedure of assembling a round aerial shell.
Note: I do NOT recommend the average person to try this! This will be illegal to do without licensence in many cases, it is on your own response wether you do this legally or not.
When working with fireworks it is very important to use proper safety gear while making. It is recommended to wear faceshield or safety goggles during the making. While making the shell, one should do it away from heat souces, such as candles, cigarettes, stoves etc.
If I somehow throw around with a lot of foreign words or have any questions, feel free to ask me.
First, let's see what a typical round aerial shell looks like:
Step 1Shell parts
Shell parts
Let's start making the aerial shell (from now on it will be mentioned as 'shell')
Shell hemispheres
You will need two 3" paper hemispheres to make this shell. Note that the hemispheres themself are actually not 3", but smaller, since there must be room for pasting and quick match to make the shell fit in the 3" mortar tube.
Stars
A batch of 75 grams of 10 mm pumped "Tiger tail" stars were made for this shell, however only 70 grams were used. Remember always to make more than you need. It's better to have a bit more, than be needing. The stars were primed in meal black powder to ensure ignition. Since Tiger tail stars ignite easy, you might find that this might be unnecessary. If a 'rising comet' is desired, a 20 mm or 3/4" comet is pumped with the compostion. Make sure that the comet has a burn time equal to the time fuse or spolette (3 seconds).
Tiger tail stars:
Potassium nitrate..................44
Charcoal (Pine airfloat)........44
Sulphur....................................6
SGRS or Dextrin.....................6
Chemicals can be obtained at:
Skylighter.com
Bursting charge
'Meal coated rice hulls' was used in this shell.
Time fuse
A 'spolette' is a small tube, where black powder is confined in it. This will act as a time fuse, however one can also buy time fuse from such sites as:
Skylighter.com
Pasting
30-40 lbs kraft paper in ~70x15 mm strips are used for pasting the shell using the 3-strip pasting method. If another pasting method is desired, the strips might have to be longer or wider. A glue is needed to paste the strips to the shell. Wheat paste is a cheap solution that works well.
Find out how to make it at a tutorial I made:
Wheat paste tutorial
Wood glue thinned with water can be used, however it is much more expensive.
Lift charge
A lift charge is needed to shoot the shell out of the mortar. Approximately 15 grams of good granulated or corned black powder works well. More or less might be used depending on the quality.
Ignition
For igniting the shell either a piece of visco fuse and quick match or shoothing-wire and an e-match can be used. In this tutorial a piece of shooting wire and e-match was used. Note with this way you will need a power supply, and that you can not light the shell with a lighter
Other
You will also need lifting cup, paper tape, scissors, drill, "gummed paper tape" or kraft paper, tissue paper, brush, hot melt glue gun, cotton twine and string.
284 comments
1-40 of 284next »
Jul 11, 2011. 1:56 PMkclarke4 says:
would it work ok if you made your own time fuse
Jul 3, 2011. 6:05 PMfellbaum says:
if i made this i would modify the steps because me being paranoid i would not want to use a hot glue gun due to the fact that the metal tip is hot an thus may cause it to prematurely explode, i would use a different glue or use the paper mache method previously stated in step four.
Jun 7, 2010. 10:07 PMbaseball05 says:
What happens if i just fill a 3 inch shell with flash powder, and use flash powder as a lift charge?
Jun 28, 2010. 5:38 AMph1lt3ch says:
You kill yourself and everyone else around you.
Jun 30, 2010. 4:51 AMmojarabm2 says:
i don't think so! every thing you have to run , probably has a spicial danger. just take care of your math!
Jul 3, 2011. 11:59 AMlperkins says:
I don't know about flash powder, but flash paper and flash cotton are what is generally used for indoor pyrotechnic displays as they produce less explosive force and little or no smoke. It should be safe, but you should be sure to have something solid to stand behind,and a lack of valuable objects nearby when you're testing it and good fire-suppression.
Jul 2, 2011. 4:12 PMcpruitt1 says:
this may sound stupid, but what is the benefit of the rising comet? what does it do?
Jul 2, 2011. 7:35 PMbadideasrus says:
as said on page one (i belive) the rising comet will catch fire when the lifting charge is ignited, and will act like a tracer round for a gun, marking the trail of the mortar shell through the air.
Jul 1, 2011. 11:02 PMashreeve says:
Sorry new at this and i am confused about the line "insert a piece of visco fuse it" could you clarify?
Jun 30, 2011. 8:14 PMCrLz says:
Fascinating Ible! Awesome!
Apr 28, 2011. 12:47 PMct_brown says:
I am writing a research paper for my chemistry class and I was wondering if anyone could tell me how to make patters like stars and hearts with fireworks
Jun 30, 2011. 3:04 PMthen says:
pack them just right
Jun 6, 2011. 4:42 PMultralegomaster5096 says:
Another thing, if you aren't already isolated, i suggest moving before doing this. If you set off that stuff...
Apr 16, 2011. 7:41 AMxorineo says:
Man that looks so good and professional made! I am also a fireworks enthusiast! I have also a website to share my passion: http://howtomake-fireworks.com/
Mar 16, 2011. 7:24 PMprojectguy says:
Just saying, pyrocreations.com is a good place to buy fuse and other supplies.
Feb 27, 2011. 9:09 AMrayrayell14 says:
this is pretty awesome im gonna try and make it wit my cuzins and my little 8 year old sister
Aug 11, 2010. 9:44 PMcory.smith says:
I think you've got some really great information, but there are some things I wish you would have covered. It is a no brainer that people would keep black powder away from heat, but rarely do they think of sparks or static electricity.
That is the biggest risk when working w/ pyro like this, because it is very hard to control, and will ignite very easily. Keep the ventilation up and the air damp. Ground yourself to the area, and DO NOT sit in a rolling chair.
Shell making enterprises in the US can't use nails in the construction of their wooden work tables, and use a fully sealed, and triple grounded electrical system. Every building has a copper plate which is grounded, which everyone touches on their way in and out of the building. Same thing on the storage magazines. Also have a ground chain and spike on the trailers, which get grounded at the site...
Seriously, static sucks...
Also, read NFPA 1123. Pretty much the gold standard on this.
Pyro certification can be had by passing the PGI exam, our regulating body. www.pgi.org
Jun 17, 2010. 11:15 AMiloveairsoftstuff says:
i have some left over black powder pellets from my inline muzzleloader from failed deer hunts were i didn't get a shot. would this work for lift charge/stars/bursting charge if i ground it up or something?
Jun 18, 2010. 9:33 AMiloveairsoftstuff says:
thanks. also i was wondering how to make stars. ive seen where you can roll bb's in powder, but yours look different.
Jun 19, 2010. 7:31 PMiloveairsoftstuff says:
thanks. that really helps alot. i really wish i could make these. ugh parents :(
Jul 6, 2010. 10:50 AMcdousley says:
wait you play with black powder but cant make fireworks? Strange parents.
Jul 7, 2010. 9:01 AMiloveairsoftstuff says:
the black powder is stuff i saved from my muzzleloader after failed deer hunts.
Jul 7, 2010. 4:40 PMcdousley says:
do you keep all of your guns in your room?
Jul 8, 2010. 11:34 AMiloveairsoftstuff says:
no and why does it matter. i have acces to them whenever i need them but we do keep them locked up. also, lets try to keep comments related to the ible.
Jul 9, 2010. 4:37 PMcdousley says:
ok so speaking of black powder could you use the muzzleloader powder since its in those solid chunks?
Jul 11, 2010. 2:51 PMiloveairsoftstuff says:
ya i used it to make a firework i just ground it up and it worked fine for what i did.
Jul 13, 2010. 3:37 PMcdousley says:
cool you could also salvage some things from small cheap artillery shells
Jun 29, 2010. 2:34 AMKryptonite says:
Ahh, good memories. This is how I found Instructables, and now I see that it's featured. *sniff* Good times.
Jul 11, 2010. 8:57 PMKryptonite says:
Yeah I did notice that!
Apr 12, 2010. 7:47 PMcdousley says:
Question ! Is firework making illegal (where i live there are no laws about setting of fireworks) I'd be afraid of losing a finger or a hand at this but it looks cool!
Jun 27, 2010. 9:18 AMArano says:
with no information where you live we can't answer your question... but a little help: it is possible that making fireworks could be seen as production of weapon or production of explosives... and both might be illegal where you live
Jul 6, 2010. 10:48 AMcdousley says:
Kentucky united states.
Jun 30, 2010. 9:29 PMdrwizbang says:
All is fun and games until you poke your EYE OUT!...love, mom.
Jun 27, 2010. 12:30 PM92033 says:
To all curiosity seekers...Potassium Nitrate is Saltpeter, available at any Pharmacy Store off the shelf. Saltpeter is used by farmers and cattle growers to control their herds or stock...adding it to their feed. The bulls eat it and get temporarily 'not interested in the ladies'...no hardons until it wears out of the blood system. Furthermore, US Army/Military adds it to food in Mess Halls during the 13 week training at Boot Camp for basically the same reason. To keep your mind on Military stuff and to dehumanize you for that period of time. If anyone thinks this is BS...join the Army and discover it for yourself. It lowers your sexual drive to nada.
Jun 29, 2010. 8:49 PMspiceyweasel says:
.....I must be immune to it, I guess. It didn't work on me. About six weeks in, it was driving me crazy.
Jun 28, 2010. 5:42 AMArcticNemo says:
Military chow does not lower sex drive. Being yelled at 24/7 and living around a bunch of other guys does that. Stress, not chemicals. So, to all curious truth-seekers, a reference below, you're welcome. http://www.snopes.com/military/saltpeter.asp
Jul 4, 2011. 4:36 PMrcisneros says:
lol. prior service? you nailed it though.
1-40 of 284next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
59
Author:pudi.dk
