Step 5Lifting charge
The black match will be a prime for the time fuse and make it easier to ignite. Without it the time fuse might fail to ignite and make it a dud shell.
The next step is the lift. Take your desired lifting cup and poke a hole in the bottom, big enough to put the quick match or shooting wire through. The quick match or shooting wire should be long enough, so that when the shell is loaded in the mortar, there will stick a bit out of the mortar. If you use quick match insert a piece of visco fuse it. This will be the delay between when the shell is ignited, till it shoots out of the mortar.
Next put the quick match (not the visco fuse end) or shooting wire through the hole punched in the lifting cup. If using quick match, tear a bit of the paper off the end, so that the black match will be exposed. If using shooting wire, attatch your e-match. Next slide the quick match or shooting wire back, so it centres in the middle of the lifting cup. Secure the hole with a bit of hot glue or gummed paper.
Add you lift charge in the lifting cup, in this example 15.3 grams of pulverone was used. The amount used all depends on the quality of your black powder. The rule of thumb is to use approximately 1/10 lift of the shells weight. The shell's final weight (everything included) was around 150 grams.
6
comments
Add Comment
pudi.dk (author)
says:
pudi.dk (author)
says:
Add Comment
