Step 6Almost done...
Cut either a strip of gummed paper or kraft paper. The strip should be long enough to fit all the way around the lifting cup plus a little more. Cut the strip halfway all the way down with a distance of ~1" as shown on the picture. If you're using gummed paper activate it with water, if using kraft paper, brush with layer of wheat paste.
Wrap the uncut part around the lifting cup and the cut part around the shell as shown on the picture. Again, make everything as tight as possible.
If you want to add a rising comet to your shell, attach it the same way as the lifting cup was attached: Cutted-up strip with glue and hot glue. About 2 mm of the comet should be exposed to ensure ignition.
5
comments
Add Comment
pudi.dk (author)
says:
Add Comment
