3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Make Fireworks
Step 7Finished aerial shell
The shell is now finished. It is a good idea to attach label in case you keep the shell over a longer time, so you will know what type of shell it is, which stars, amount of lift etc.
The shell can now be fired, but please note that this is obiously the most dangerous part of it all, so proper safety gear must be used.
First of all your eyes, fingers and ears are the most important thing to protect.
Wear safety goggles/face shield, fireproof gloves and ear plugs/earmuffs during firing (as a minimum!)
When firing, you can either use a mortar stand to hold your mortar tube if you have one, or you can bury the mortar tube in the ground about 2/3. Next the shell is loaded to the tube with the quick match or shooting wire sticking out - the shell should fall freely, without any help to make it reach the bottom. Also please take care of your surroundings: The shell should be fired a long distance away from people, houses and flammable objects. Run a good long distance after igniting the fuse. If you want to film the shell, it is recommended to be at least two persons: one will be filming, the other will ignite the fuse.
If the shell should somehow fail to lift properly and explode on the ground, you will be glad you did wear safety gear.
Sometimes a "flower pot" happens (mainly if the shell is not sealed well around the time fuse, or if the spolette is not rammed solid enough), which is simply the shell explodes in the mortar, shooting stars into the sky. The mortar may or may not fracture when this happens, but this is where burying the mortar comes in handy: the surroundings of the mortar will arbsorb most of the shock, and the fragments may not fly very far.
The shell was fired in front of a small audience (consisting of my family) I excuse the annoying voices/laughs/whatever.
Hope you enjoyed this instructable, which is my first one.
To find out more about pyrotechnics go to:
PyroGuide.com
-pudidotdk
11 comments
Feb 27, 2011. 9:09 AMrayrayell14 says:
this is pretty awesome im gonna try and make it wit my cuzins and my little 8 year old sister
Jun 29, 2010. 10:32 AMChikote says:
Just perfect!!! Congratz! Amazing job u did here!! :)
Jun 29, 2010. 7:43 AMpopscott3 says:
That is the coolest! I have always wonderd how fireworks work. And the vid was AWSOME!
Jun 27, 2010. 8:43 AMhossmonkey says:
That is the "bomb"! " :-)
Mar 15, 2010. 6:20 PMteslafan100 says:
that was AWESOME!!!!!1
Jul 9, 2008. 6:20 PMstimps says:
Wow, how thorough! I've seen a lot of very bad and not safety-concious firework lessons, and yours is truly superb. Great job (and thanks for the film)!
Jul 8, 2009. 2:17 PMndinitz says:
I second the motion.Pr
Jun 23, 2009. 6:57 PMProud American Pyro says:
That was a great instructable! Very nicely put together.
May 30, 2008. 1:46 AMMattrox says:
AWESOME cant wait to shot that at my neighbor (he is so annoying wana get rid of him) Joking
Apr 24, 2008. 12:09 PMMoreno says:
Nice instructable !!!!! Are you active on apcforum.net????
Sep 14, 2007. 5:19 AMstihl88 says:
Absoluitly fantastic Instructables and very nice to see you set it off at the end. Maybe you might consider adding the method of pumping your stars out. Well Done!!! 10/10
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
59
Author:pudi.dk
