How to Make a Forklift With Makeblock
14,091
73
9
Published
Introduction: How to Make a Forklift With Makeblock
About: Makeblock was founded in 2012 as the world's first open-source robot and programing platform. With more than 400 mechanical components, electronic modules, and software tools, we are determined to bring mean...
This is one form of Makeblock. Ultimate Robot Kit With mechanical parts and electronic modules provided in this kit, you could add different transformation to your robots.
Step 1: Assemble Base Platform
Parts list:
2 x Beam 0824-144
3 x Beam 0824-96
1 x Bracket 3x6
1 x Plate 3x6
13 x Screw M4x14
4 x Screw M4x8
6 x Nut M4
Step 2: Install Wheels and Motors
Parts list:
2 x Timing Pulley 90T
2 x Shaft Connector 4mm
2 x Tire 68.5x22mm
2 x DC Motor-25 Bracket
2 x DC Motor-25
8 x Screw M4x14
4 x Screw M3x8
4 x Headless Set Screw M3x5
Step 3: Install Another Two Wheels
Parts list:
2 x Tire 68.5x22mm
2 x Threaded Shaft 4x39mm
4 x Flange Bearing 4x8x3mm
2 x Nut M4 2 x Shaft Collar 4mm
6 x Plastic Ring 4x7x2mm
2 x Headless Set Screw M3x5
Step 4: Install Lifting Fork
Parts list:
1 x Beam 0808-184
1 x Plate 3x6
8 x Plastic Ring 4x7x2mm
2 x Screw M4x8
4 x Screw M4x22
4 x Nut M4
Step 5: Assemble Lifting Fork
Parts list:
2 x Beam 0808-88
3 x Link Rod
2 x Bracket 3x3
2 x Timing Belt Connector
2 x Bracket 3x6
1 x Timing Belt 240MXL
2 x Screw M4x22
2 x Screw M4x14
14 x Screw M4x8
12 x Nut M4
Step 6: Install Lifting Frame
Parts list:
2 x Beam 0808-184
4 x Threaded Shaft 4x39mm
2 x Nylon Pulley with Bearing
4 x Bearing 4x8x3mm
4 x Screw M4x14
10 x Plastic Ring 4x7x2mm
Step 7: Install Timing Pulley
Parts list:
1 x D Shaft 4x56
1 x Timing Pulley 18T
3 x Headless Set Screw M3x5
Step 8: Install DC Motor
Parts list:
1 x Beam0808-88
1 x Link Rod
1 x DC Motor-37 Bracket
1 x Timing Pulley 62T
1 x DC Motor-37
1 x Shaft Connector 4mm
2 x Screw M4x14
6 x Screw M4x8
3 x Screw M3x8
Step 9: Adjust the Position of DC Motor to Tension the Timing Belt.
Step 10: Install Electric Modules
Parts list:
2 x Base Bracket
1 x Makeblock Orion
1 x Battery Holder for (6) AA
1 x Me Bluetooth Module
1 x Me Dual Motor Driver
9 x Screw M4x14
2 x Screw M4x8
11 x Nut M4
Step 11: Wiring
Parts list:
1 x RJ25 Cable-20cm
1 x RJ25 Cable-35cm
3 x Motor Cable
3 x Terminal Block
3 x Ferrite Ring
Step 12: Connect DC Motor-37 With Me Dual Motor Driver.
Step 13: Plug Dual Motor Driver and Bluetooth Module Into Port 2 and Port 5 Respectively.
Connect Battery Holder with Orion board.
Step 14: The Finished Forklift
    • Planter Challenge
      Planter Challenge
    • Woodworking Contest
      Woodworking Contest
    • Clocks Contest
      Clocks Contest
    9 Comments
    limit of weight some, some one had tested?
    I dont understand step 5 at all. it isnt clear at all.
    am I the olny one cant find the spiky looking pieces on step 5
    Very professional looking build! What is the maximum weight that the forklift can lift?
    Have a great day! :-)
    this is a very good design.I have a question though,why did you position the front wheels far from the fork base? with this design the weight will destabilise the lift and make it fall forwards as the center of gravity wil become outside of the lift.i hope i made sense.
    You make sense. A better solution is to put the front wheels at the very front of base platform. Thanks for your advice. :)
    Cool! How about a video of it in operation?
