Introduction: How to Make GRBL + CNC V3 Shield Based Mini CNC Machine From Scrap DVD Drive
This CNC is based on GRBL0.9 Firmware and CNC V3 shield GRBL is Hacked for Z-axis Servo.
CNC Shield & GRBL combinly works very preciselyIt is loaded with very useful functions like Hard limit, Soft limit, Homing, etc
This is about how to make
GRBL+CNCV3 shield+Arduino based CNC machine
This guide include all necessary instruction required
like How to assemble CNC machine
How to Load GRBL to arduino
Inkscape extension installation
GRBL Configuration & G-code streaming
It is loaded with very useful functions like Hard limit, Soft limit, Homing, i will guide you in detail how to Make GRBL Based mini CNC machine at home
Step 1: Watch Video to Know How to Make
Watch this video it will clear you how to make and operate CNC machine
Step 2: Material Required
This are the list of some use full material required
- Arduino UNO--------------------------------------QTY- 1
- CNC V3 Shield------------------------------------QTY-1
- servo motor----------------------------------------QTY-1
- A4988 Stepper driver shield--------------------QTY-2
- Old scrap DVD Drives---------------------------QTY-2
- Some push buttons as limit S/W---------------QTY-2
- A acrylic sheet for base
- Pen holder (slavege from DVD Drive)
- Some wires
- Hardware like nut bots etc.
Step 3: Software Required
1. Arduino IDE
GRBL LIBRARY :- Click here to download
2. INKSCAPE
SERVO CONTROL EXTENSION :-Click here to download
3. UNIVERSAL G-CODE SENDER : - Click here to download
Step 4: Machine Assembley
- Place X-axis Horizontally on the bolt mounted on acrylic sheet
- Four bolt mounted on a metal sheet to fit Y-axis on it
- Now place the Pen up down holder on y axis whit the help of A bolt through the center
- Now place Y-axis on metal sheet and place it vertically on X-axis
- Now fit servo motor so that it will move z-axis which is our pen up and down
- Now mount CNC shield on Ardunino
- Do wiring A shown in wiring circuit as in Next step
For better understand please watch Video & pic attached here
Step 5: Wiring Diagram
Do wiring as shown here in image
Limit switch are optional
You can use them by changing the GRBL setting as below
$21=0 (hard limits, bool)
to
$21=1 (hard limits, bool)
Step 6: GRBL Loading to Arduino
Link to download GRBL Setup
http://www.mediafire.com/file/c36xny4qw9b7s5k/MI_G...
Download the library file unzip it
and load to arduino
Now go to File>Example>grbl upload compile and upload code to arduino
Note:- delete any previously loaded GRBL library
Step 7: G-CODE Setup in Inkscape
Again we are using here INKSCAPE software to make G-code
As we are using GRBL & CNC Shield for this machine s
o it will not support a servo motor as a Z-Axis
so here some hack by doing so we can able to manage Servo works on Z-axis
you need to add MI Extension here to get it work with Z-axis Servo
Download link http://www.mediafire.com/file/nl4w871suk192x2/MI_...
after download add this files to the
inkscape directory>Share>Extension folder
Now open inkscape set page size 40 x 40mm
draw what you want to plot
select image go to convert to path
then go to extension click on MI GRBL Z-AXIS SERVO CONTORL
Servo up = M3
Servo down = M5
X-axis speed = 2000
Y-axis speed = 2000 S
ervo angle = 90
Delay = 1
Directory = as per you convenient or keep as it is
File name = as per you convenient or keep as it is
Clik on Apply now you G-code is saved @ location you mention
Step 8: GRBL Configuration & Streaming G-code
Download link for Universal Gcode sender
https://www.mediafire.com/?2l16dvqivwgc9el
Open Universal G-code sender (Arduino must stay connected with PC/LAPTOP)
Select COM port
Set Baud rate 115200
clik on "OPEN"
go in "COMMANDS" Tab
enter $$ for GRBL configuration
Example Suppose we want to change the $0(step pulse, usec) value from 10 to 20
so enter in command line $0=20 & hit enter its done
My GRBL SETTING
$0=10 (step pulse, usec)
$1=25 (step idle delay, msec)
$2=0 (step port invert mask:00000000)
$3=0 (dir port invert mask:00000000)
$4=0 (step enable invert, bool)
$5=0 (limit pins invert, bool)
$6=0 (probe pin invert, bool)
$10=3 (status report mask:00000011)
$11=0.010 (junction deviation, mm)
$12=0.002 (arc tolerance, mm)
$13=0 (report inches, bool)
$20=0 (soft limits, bool)
$22=0 (homing cycle, bool)
$23=0 (homing dir invert mask:00000000)
$24=25.000 (homing feed, mm/min)
$25=500.000 (homing seek, mm/min)
$26=250 (homing debounce, msec)
$27=1.000 (homing pull-off, mm)
$100=5.000 (x, step/mm)
$101=5.000 (y, step/mm)
$102=100.000 (z, step/mm)
$110=500.000 (x max rate, mm/min)
$111=500.000 (y max rate, mm/min)
$112=500.000 (z max rate, mm/min)
$120=10.000 (x accel, mm/sec^2)
$121=10.000 (y accel, mm/sec^2)
$122=10.000 (z accel, mm/sec^2)
$130=40.000 (x max travel, mm)
$131=40.000 (y max travel, mm)
$132=200.000 (z max travel, mm)
ok
Now time to stream Gcode to machine go to "FILE MODE" Tab Brows your gcode file and hit enter thats it
youR machine start plotting Hope you like this Comment below if any doubt
