How to Make Green Fire From Laundry Booster
Introduction: How to Make Green Fire From Laundry Booster
In this guide, you'll learn how to make your own boric acid from borax and other common chemicals to produce a green flame when mixed with methanol.
Green Fire Safety Information
Boric acid is a relatively safe household chemical. This is an outdoor project. There isn't a lot of smoke produced, nor is it particularly toxic, but the heat is intense. It will set off your smoke alarm.
The borax i used for this experiment is from the brand 20 mule team witch has 99.5% purity (there is about a half of 1% of naturally occurring trace minerals) so I recommend using it for this experiment.
The only hazardous part of the experiment is making the boric acid (because of the use of HCl), but you can avoid this part by buying it, or you can use copper sulfate as an alternative (sold as a root killer).
The only gas produced in this reaction is CO2 and some water vapor, because of the combustion of methanol; Borax and boric acid don't burn up or produce gases, simply the electrons of boron get exited because of the energy produced from the combustion of methanol and the boron electrons re-emit this energy as a green flame.
    • Paper Contest 2018
      Paper Contest 2018
    • Pro Tips Challenge
      Pro Tips Challenge
    • Trash to Treasure
      Trash to Treasure
    would this be toxic in the air if released? i have a class of students doing an experiment with it. it involves burning it
    You really can't say that this does not produce toxic fumes when you tell someone to use laundry booster! There are many compounds in there and you can't say what they will break down into. To do this experiment safely just find some copper turnings, grind them into a find powder, let sit in a little sodium chloride solution overnight, rinse, mix with some methanol and light, you might get some yellow and green flames from this, the yellow is from the sodium if you didn't rinse well. Better yet, just stick a copper wire directly into a flame, of course insulate what you hold.
