How to Make Homemade Incubator | Egg Hatcher at Home
3,041
12
7
Published
Introduction: How to Make Homemade Incubator | Egg Hatcher at Home
About: I enjoy making new Instructable
Here is a neat and easy project on how to make a chicken egg incubator. Doesn't take long to make. The eggs will hatch in 21 daysIn make a simple incubator for chicken ,duck, Lizard etc eggs hatcher this is the most simplest incubator you can make at your home
Step 1: Tools and Supplies You Need
We will be need
1x 12v Thermostat controller
1x 12v computer fan
1x 5 feet 23/73 220v wire
2x 2 feet 23/73 220v wire
1x 100 watt bulb
1x bulb holder
2x 12v adaptors
2x 12v plugs
1x 220v plug
Handfull of zipties
Tools you need
Wire cutter
electrical tape
Screwdriver
Drill machine
For the Egg tray
Big plastic tray
2x 15inches wood
2x aluminum bowl
Step 2: Drilling the Holes for the Wires and Parts to Fit In
We need to drill holes on the points where I marked
from the sides the wires will come in from the front we have to make a 4 holes for circuti wires and 4 holes for sticking the circuit
from the other side below side fro the heat source bulb
and from the down side 4 holes for the fan so it can stick to the surface
Step 3: Wiring All the Components
I have insert the wiring of 12v wires one is for the fan and other is for the circuit both of them will work on 12v
wire the fan properly and also give supply to circuit
look carefully where I put the ground and 12v black wire will always go in GRD and other will go in 12v
Step 4: Now Is the The Time to Shine for Bulb
Now tighten the fan with ziptie and make sure the sticker part of fan is facing the heatsource the bulb so it blew aways it's heat and distribute in evenly in the whole incubator
Wire the bulb holder and tight it with ziptie
The hard part is that you have to joint the bulb wire by another wire
There are two wires going in the main wire cut half the wire and cut only one wire of it and joint them to the new wire and it will go into the circuit K0 and K1
see the pictue carfully of how to hook the wires
attache the wires to Ko and K1
wires up the 12v female sockets and 220v plug in there wires
Step 5: Make the Support for the Egg Tray to Sit
Measure 7 inches from the ground to attach wood panels with the screws
put the tray on top of it
put those almunium bowls on the box ground
Plug in the Incubator
Voila Your incubator is ready just put some eggs in the tray put the water in almunium bowls and you are ready to hatch chicks out of eggs
    • Woodworking Contest
      Woodworking Contest
    • Planter Challenge
      Planter Challenge
    • Clocks Contest
      Clocks Contest
    7 Comments
    It would be even better if you could add something that would rotate the eggs too. That was the really inconvenient part of hatching chicks when I was in college. Someone had to come in on weekends just to rotate the eggs.
    I will make an fully automatic incubator in coming instruchables.
    I will be looking forward to it.
    Keep seeing the same basic mistakes in homemade incubators:
    1 - Incubating eggs breathe (need oxigen, release carbon dioxide)...I see no air vents in your incubator...
    2 - Only one lamp as a heat source... If it blows out (say during the night), there goes the hatch... Instead one 100W lamp, try connecting 2 x 50W in parallel...
    Cheers
    Very good pointing out I forget to include vent holes for fresh air coming in,putting two bulbs is also a good option.
