3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Make Indonesia's WajanBolic or PanciBolic (USB)
How to Make Indonesia\
My third instructables! Now I'm gonna teach you all Indonesia's Wifi Antenna made of wok.
NOTE: I didn't invent this cool thing.
Step 1Gather the parts!
Gather the parts!
What you need:
1. Extended USB cable (click here)
2. Wok or the cover of a saucepan. (I use the cover of saucepan, because it's lighter).
3. USB WiFi
4. 3" PVC pipe. You need at least 1m. (depending of your wok size)
5. 1.25" PVC pipe. You need just a little of it, at least 5" long. Cut the middle (like in the picture)
6. Doff for 3" pipe (doff=pipe cover, holed in the middle. One of them connect to 1.25" doff using screw)
7. Doff for 1.25" pipe (stick aluminium foil inside then hole in midle, the other don't need to be holed)
8. Aluminium foil
9. Drill
If you don't understand, see picture
39 comments
Oct 2, 2011. 8:30 PMdragonclan1tnt says:
this is how to get the focal point http://www.satsig.net/focal-length-parabolic-dish.htm dont know y they didn't include thins in tho
Jul 10, 2008. 12:18 AMdan moulton says:
Cool, how do you calculate the focal point? And whats a doff, haven't heard that term before.
Jul 20, 2011. 7:16 AMjokoh says:
doff = pipe cap
Jul 12, 2011. 8:47 PMaredee says:
please tell me how we count the focal point?
Feb 19, 2010. 3:33 PMtransitionality says:
 The design is ingenious -- the way you've combined a parabolic antenna with a waveguide antenna is both stable and cheap! Well done.
However, I don't see why you have the 1.25'' pipe piece in there. What does it do? Wouldn't the design work just as well without that piece?
May 15, 2011. 12:44 AMtongak says:
i think the small piece work as holder for the wifi modem
CMIIW
Apr 27, 2011. 9:09 PMtezakuri says:
hebat pisan mas...pokonamah hidup indonesia.......
Feb 26, 2009. 12:26 PMsunarno says:
I have use this on to share internet connection with my neighbourhood. Detail information for this wajanbolic I found on this link http://opensource.telkomspeedy.com/wiki/index.php/Wajanbolic_e-goen
Mar 1, 2009. 3:57 AMlegless says:
What an extremely unuseful link to anyone who does not read Indonesian languages.
Mar 1, 2010. 3:14 AMfegundez1 says:
google translator!! works  great
Feb 5, 2010. 3:47 AMzgeng says:
wahhh..mantap bro...udah w buktiin wajanya mang top wat nyolong wifi
indonesia jaya...
Jan 19, 2010. 5:13 AMbayucandra says:
Millmore, i am not sure if it is have to be 1m, but i think you have to check the calculation detail about this equipment. There is standard calculation for this equipment including detail about the pipe length needed, i was read it some month a go. You may find at the link some where he gave.
But the bad news, standard calculation have been made in Indonesian language, you need a dictionary maybe :).
Sep 20, 2009. 8:38 PMadvante says:
Saya butuh yang buat internetan gratis. Rumor kata orang, temen bisa pake sampai 500 kbps gratis, tanpa batas. Butuh yang itu. ___________________________________________________________ I need that for free internet. Rumor, peoples and friends said it can reach until 500 kbps, free without limit. I need that one.
Jan 13, 2010. 12:38 PMpyroal says:
what language are you speaking
Sep 9, 2009. 12:39 AMchiangkool says:
edian ik.. indonesia ?? hehehe.. perlu di paten nich.. sebelum di colong ma malaysia nich..
May 26, 2009. 2:11 PMgrimrp3r says:
hah? indonesia? baru tau gw. btw tuh panci ukurannya berapa?
Apr 17, 2009. 10:34 PMkoma4194 says:
i ve try this entenna Using Aztech 2.0 USB modem. but long extend cable cannot be detect by my PC.. My PC USB hub is 2.0.. any idea.. pls help
Mar 4, 2009. 12:08 AMXipir says:
Juragan, tuh tutup panci diameter brapa yak?
Mar 2, 2009. 2:58 AMconradturner2001 says:
There are several links on the web including the formula you need to calculate the focal point for the parabola. Have used a seive and similar to gain access to free internet services outside normal range of usb dongles and have also managed to link across our local park between laptops (1km+) just try words like diy wifi antenna. good luck
Mar 1, 2009. 9:38 AMWafflicious says:
whats it do?
Feb 27, 2009. 2:23 AMdariel24 says:
do you know what WajanBolic or PanciBolic means? it means wok or pan lid bolic (parabolic counterpart) wok and pan lid is cheap and common in indonesia LOL
Feb 25, 2009. 7:24 PMilmubebaspakai says:
yay... Indonesia, Obama learned such stuffs while he was a kid here LoL Obama nyalon juga ga yah jadi presiden Indonesia?
Feb 27, 2009. 2:20 AMdariel24 says:
bener tuh. dia SD dimana? agak lupa juga nih tapi yang gw tahu masih di jakarta kan?
nyalon jadi presiden indonesia? maksudnya? jadi tukang salon gitu? lol
indeed. where is his Elementary School? i'm bit forgot. but what i know is it's still in jakarta
Feb 26, 2009. 7:10 AMVindoch says:
Hai indonesia! gile baru pertama kali gua liat ada comment bhs ind di sini bangga aku!
Feb 27, 2009. 2:17 AMdariel24 says:
setuju! keren juga nih...
perasaan gw cuma pernah liat comment inggris dan sekarang indonesia di instructibles ini... yay! cool!
Agree! it's cool
i only see english and now indonesia comments in this instructibles... yay! cool!
Feb 26, 2009. 12:51 PMKilla-X says:
It's too bad you couldnt probably get a wifi connection with an ipod using this.. Im confused. Is this a Wifi range booster and a Wifi Pickup range boost? I know some devices allow external antennas for long-range pick up.. But not ipods!
Feb 26, 2009. 11:56 AMKaljakaaleppi says:
I have used succesfully a sieve for a thing like this... Without measuring anything at all, we did manage to get an incrased signal while lying on anchor i a bay at a beautiful tropical location.
Feb 26, 2009. 8:30 AMbluestripe says:
is a wifi max ok to use as the wifi thing
Feb 26, 2009. 6:06 AMmillmore says:
Are you sure you need 1m of 3" pipe? Your picture shows about 30cm. Step 3 is a little vague. How long should the foil and non-foil sections be? Is the 1.25" pipe there to hold the USB stick in place? If so, how does it do that? Thanks Martin
Feb 26, 2009. 5:30 AMNeuroPulse says:
Greetings, How about some descriptive information in the introduction on what this thing is. What is the range? Anyone have a link on this? I can usually find anything in wikipedia, but can't find this. Thanks
Oct 4, 2008. 8:02 PMShadetree Engineer says:
Very nice way to mount a collector to a dish. I would wonder about the way the adapter is mounted though, the distance into the 3 inch tube that the adapter is placed can change the performance. At least that is what I found on a tube I built out of a fire extinguisher measuring about 3 inches in diameter. At first I had placed my adapter all the way in, like you did here, with just the connector outside of the tube, but I found that I got a better signal by pulling the adapter most of the way out. More info here: Wireless Internet Cantenna Wrapping PVC in foil is a good idea, I use a similar approach on the cone of my last wi-fi antenna: Conetenna I would expect the PVC to have no reduction in signal. The collector you built will probably cover a larger dish, I've heard from some really picky designer types that the outer edge of a parabolic dish shouldn't be counted on for much of a signal, so if you can find a reflector that extends a bit beyond what the collector is covering, the better. I would recommend combining your PVC collector with this: Parabolic Reflector
Aug 14, 2008. 12:18 AMstratohellsing says:
Uber Cool... Time for wifi hacks... LOL
*Keren banget... waktunya nyolong wifi gratisan, hahaha*
Aug 11, 2008. 7:42 AMinertia18 says:
May I ask, can the signal/radio waves pass thru the PVC, as it shown here its inside the PVC and theres no metallic or foil inside to reflect thru the saucepan lid/wok. Can you enlighten me. I like to work on this. thanks in advance:)
Jul 7, 2008. 12:06 AMelectrophobia says:
What is the difference between a single USB wi-fi and this thing?
Jul 15, 2008. 3:52 AMfrollard says:
This transforms the usb from omnidirectional (relatively weak in all directions) to a 'beam' antenna, which focuses the signal to be entirely directional. If you know where you're shooting, these are much better at attaining a strong signal to that destination. With a cantenna on each end of the wifi connection, you can shoot for miles (google wifi shootout). I think the record is over 40 miles with a standard unamplified signal, between two mountain peaks in death valley. To do that they use huge repurposed satellite dishes.
Jul 16, 2008. 12:59 PMelectrophobia says:
so here is your five stars.. Great instructable..
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
19
Author:huang.wencong
