3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Make Iodine from Sulfuric acid and an Alkali Metal Iodide
video How to Make Iodine from Sulfuric acid and an Alkali Metal Iodide
How to make elemental iodine from sulfuric acid and sodium or potassium iodide.
Warning: Reaction must be done outside or in a fumehood due to production of toxic gases including hydrogen sulfide. Concentrated sulfuric acid is extremely corrosive and dangerous and should be handled in glass containers at all times. Always wear gloves when working with it and thoroughly wash any spills with water. Wear eye protection at all times.
The Iodine vapor that is formed throughout most steps of this instructable is toxic and will also stain EVERYTHING it comes in contact with. You can see from the video that the work-area became an absolute mess. So do not do this indoors.
First, get your sodium or potassium iodide and completely dissolve it in a minimum of water. Then place it into an ice bath to keep it cold.
Second, add concentrated sulfuric acid directly to the solution and constantly stir. As you add it will produce iodine. At this point, it will start producing toxic gases including hydrogen iodide, sulfur dioxide, hydrogen sulfide and vaporized sulfuric acid. You have to perform this reaction outside or in a fumehood.
At first the mixture will become pasty and eventually liquefy.
Once it's liquefied, pour it directly into cold water (the ice bath itself is useful for this) and stir it up. Then let it settle for ten minutes or so.
The iodine will settle to the bottom so pour off the water and acid.
The iodine will still be contaminated with acid so you'll need to add water and pour off several times to get out most of the acid.
Filter it and now you have a solid plug of iodine.
It's usable as-is for most purposes but you can purify by placing it in a beaker with a ice-filled round bottom flask on top. Then heat the beaker. The iodine will vaporize and deposit on the flask.
A cool reaction is to take some iodine and pour magnesium powder over it. It will react to form a purple cloud of iodine vapor. If it doesn't react quickly enough, just add a drop of water.
While the iodine vapor is cool, it's also toxic and this reaction should be performed outside.
More cool stuff at our site at http://www.nurdrage.com
15 comments
Jan 19, 2011. 6:28 PMJohenix says:
You can avoid the hydorgen sulphide (made by the reduction of sulpheric acid by the hydrogen of hydrogen iodide) by the use of manganese dioxide.
Aug 21, 2009. 9:17 PMPie Ninja says:
Would the slightly impure Iodine be usable for making Nitrogen Triiodide?
Sep 14, 2009. 10:59 AMSwindle35437 says:
you can make it pure and then use it
Sep 15, 2009. 12:31 AMPie Ninja says:
how would one purify it?
Oct 6, 2009. 11:07 AMSwindle35437 says:
heating it with a cold bottle on top
May 17, 2009. 9:23 AMlil jon168 says:
dude sulfuric acid can eat your flesh
Aug 21, 2009. 9:16 PMPie Ninja says:
lol
Jul 27, 2009. 11:23 AMdioblo2345 says:
did you know most stores like walmarts sells iodine tablets in the camping section!!! anyway nice vid ill give you a 5.00 rating
Jul 27, 2009. 2:56 PMdioblo2345 says:
i dont remeber it just said iodine tablets
Mar 30, 2009. 7:43 AMBiopyro says:
Another excellent well thought out and easily followed procedure. 5*
Mar 29, 2009. 7:05 PMDELETED_GuardianFox says:
(removed by author or community request)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
614
Author:NurdRage(NurdRage)
NurdRage is a dedicate group of science nerds trying to further amateur science with direct how-to instructions in video format. We saw what was already online and we thought "we could do better"... s...
more »
