How to Make Joss-Style Incense by RaNDoMLeiGH
Featured
Step 2: Mix ingredients with water and make into a ball.
Add, just a TEENY bit at a time, plain tap water. It can be hot, cold, whatever. You'll want to mix it with your fingers. It's a lot like making a pie crust -- it will create little crumbs, and then, all of a sudden, make a ball.
The ball should have no cracks. This part is very important. Add just a couple drops at a time until the cracks disappear.
The guar gum should feel a little slimy. If the sandalwood is not holding together well, add more guar 1/4 tsp at a time until the ball sticks together.
Once you have enough water, try rolling a test cone with your fingers by just pinching a little off and forming it into a cone, standard incense size. If it holds the shape well without slumping, you are ready. If it cracks when forming, add a teensy bit more water and try again.
When the test cone holds together, you are ready to start extruding sticks. (You can also make the dough into cones if you'd rather.)
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
