How to Make Magnetic Message Board
329
6
Published
Introduction: How to Make Magnetic Message Board
About: Wish Your Support.
A simple picture frame and a piece of sheet metal come together to make
an upcycled magnetic message board. It's perfect for pantry doors, entry ways, offices and dorm rooms.
Step 1: Tools
  • paintbrushes (two small sizes)
  • sandpaper
Step 2: Materials
  • picture frame (wide and flat is best)
  • 16-gauge galvanized sheet metal (cut to size)
  • magnets
  • picture hanger and picture hanging wire (if not already attached to the frame)
  • sample-size paints
  • painter's tape
Step 3: Pick Up Some Sheet Metal
Most hardware stores or metal shops will cut galvanized
sheet metal for you. Use the back insert of the picture frame as a guide to determine the correct size.
Step 4: Prep Old Picture Frame
Clean and sand the frame to remove the existing finish. This will help the new paint adhere to the surface.
Step 5: Apply Primer
Apply two coats of paint to the frame. Let the first coat completely dry before applying the second.
Step 6: Create Your Design
When the paint is dry, use painter's tape to create a
pattern on the frame. We did basic stripes. Make sure to press the edges of the tape down to prevent the paint from bleeding through.
Step 7: Add Accent Color
Apply paint right over the painter’s tape and the entire frame. Let dry and then apply a second coat.
Step 8: Let Dry and Remove Tape
When the paint is dry, slowly remove the
painter’s tape. Use a small artisan paintbrush to make any necessary touch-ups.
Step 9: Attach the Metal Sheet
Insert the galvanized sheet metal into the frame and then
replace the back and push down the staples or frame tabs to secure the pieces in place.
Step 10: Delightful Decor
Attach a hanger on the back of the frame and display your new memo board it a handy spot.
    • Oil Contest
      Oil Contest
    • Pets Challenge
      Pets Challenge
    • Woodworking Contest
      Woodworking Contest
    This is a great project. I am going to try making something like this with my kids.
