How to Make Metal Flowers
7,471
109
10
Posted
Introduction: How to Make Metal Flowers
I decided to have a go at making some more metal flowers after the great reaction I got from making these Copper daffodils
I hope from the pictures you realise they are meant to be lilies! They are quite easy to make but there is a bit of welding (nothing fancy) grinding and some heating of the metal to make a bit more pliable.
Step 1: Have a Look at the Video Below.
Have a look at the video above or follow the guide below. The materials needed for this project are some sheet metal, 6 mm metal rod and some metal primer, white or off white, green and some yellow paint.
Step 2: Marking and Cutting the Sheet Metal.
I started by using a template to mark the flower onto the sheet metal. I found this shape online. I then cut the shape out using a tin snips.
Step 3: Cutting the Stems.
I cut the 6 mm steel rod into approx 455 mm (18 inches) pieces using my angle grinder.
Step 4: Shaping the Stems.
I hit the stem (6 mm rod) a few times with a hammer on my vice to put a few small twists and bends to make it look more realistic. Then using a grinding disc in an angle grinder I tapered off the stem (rod) into a point.
Step 5: Forming the Flower Shape.
To form the shape of the flower I first heated the sheet metal with a blow torch (to make it more pliable) and then started to hammer it into shape. This process would be easier if the metal was heated in a furnace first, the blow torch cannot heat the whole flower shape to the same temp at the same time.I continued heating, hammering and using a pliers to form the shape I wanted.
Step 6: Attaching the Flower to the Stem.
To attach everything together I first put the stem (rod) into a vice to hold it and then pushed and twisted the flower onto it. With my welder turned well down (the sheet metal is very light) I tacked the flower into place.
Step 7: Adjustments.
After it cooled down I did a few more adjustments with pliers while it was held in a vice.
Step 8: Grinding Smooth.
I then used a grinding disc to smooth out the where I welded them together.
Step 9: Primer.
I then applied a coat of a metal primer.
Step 10: Painting.
After the primer had dried I started to paint the flower part. I used an off white color (2 coats) but I think if I was making more I would use a whiter color. When this had dried I then applied some green paint to the stem.
Step 11: Painting.
Using a small brush I then painted on some yellow paint onto the center of the flower. I not sure what the real name of this part is. I think it’s the stigma, style or filament.
Step 12: A Finished Flower!
A finished lily. This is what a single one looks like.
Step 13: That's It.
I hope you like these and will have a go
making them. I think if I had spent a little more time forming them they would look a bit better or if you are lucky enough to have access to a furnace even a small one and get more even heat into it, it will bend more easily. That being said I am quite happy with how they turned out.
If you would like to see how I made some copper daffodils click here: Copper daffodils
If you would like to see more projects from me you can subscribe to my YouTube Channel here:Eamon Walsh DIYThanks.
Step 14:
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    8 Comments
    Nc e! The middle bit is called the stamen ☺☺☺☺☺☺☺☺
    Wow, simple and elegant! I will have to try this.
