iImage Information
How to make cheap Nitrocellulose from ping pong balls, black powder, and acetone for use in igniters and detonators.
Step 1Mix Acetone and Cut Up Ping Pong Balls
iImage Information
Cut Ping Pong ball into small peices to make them easier to disolve in the acetone. Ping Pong balls themselves are a type of nitrocellulose, acetone will disolve them and make them easy to work with and make it possible to add black powder for a more violent ignition. After the ping pong balls are cut up and in the contianer you are using to mix your ingredients in pour enough acetone to cover the cut up balls and than add that amount again. You don't want it too think and sticky.
Simple Nitrocellulose is made by mixing 20 ml concentrated salpetric acid an
40 ml concentrated sulfuric acid and 2 g cotton ( mixing the acids before adding the
Cotton). The temperature of 20°C should not be exceeded or the mixture
will decompose veary quickly.
you can't allways use the technique shown in this instructable, because Ping Pong balls are often made of polyethylen or polystyrene.
If you want to make Celloloid you desolve nirocellulose in acetone, add some
camphor and lett the acetone evaporate.
tl;dr lurk moar, don't mess with capgun powder(ammonium triIodide is safer imho) or lose a fingernail. It might grow back, but it won't be like the others.
here's a link to some stuff that's safer to transport as a powder than capgun bullshit: http://www.youtube.com/watch?v=2KlAf936E90&feature=related
inb4 "that isn't safe at all"
Ping pong balls are made from celluloid which if you read the wikipedia article (I know, I know its unrelible and all that, but if it is used along with common sence it can have some good info) it says that celluloid is the name of a class of compouds created from nitrocellulose and camphor which is why its bad to use the ping pong ball smoke bombs (toxic fumes)
There, thats my lecture for today.
