Introduction: How to Make Ombre Crystal Cluster Earrings
Are you ready for making this couple of ombre crystal cluster earrings? It is so diverting to make ombre earrings and also very fit for autumn season. Follow me!
Step 1: Materials on How to Make Crystal Earrings:
4mm acrylic plating golden beads
6mm clear crystal beads
6mm light yellow crystal beads
6mm golden crystal beads
6mm brown crystal beads
Golden headpins
Mixed sized golden jumprings
Earring hooks
Wire cutting plier
Round nose plierFlat plier
Step 2: Make One Bead Dangle
slide an acrylic golden bead and a clear crystal bead to a headpin, make a loop by round nose plier, the bead link pattern is done;
Step 3: Make the Rest Bead Dangles for Crystal Cluster Earrings
2nd, according to the method on 1st, make 8 clear crystal bead dangles, 12 light yellow crystal bead dangles, 16 golden crystal bead dangles and 16 brown crystal bead dangles;
Step 4: Cluster the Links to Make Dangles
connect 8 clear bead dangles to a 8mm jumpring, then add one more jumpring to the the first jumpring, do the same to make other three different colored crystal bead dangles links;
Step 5: Connect the Bead Links
1st, you should make a jumprings link first, connect one 6mm jumpring, two 4mm jumprings, one 6mm jumprings and two 4mm jumprings together in order, then connect an earring hook to the first 6mm jumpring, the jumprings link is done;
2nd, connect the clear crystal bead link to the jumprings link first, then connect light yellow crystal bead link, golden crystal bead link and brown crystal bead link one by one, the ombre crystal cluster earring has been finished now;
Step 6: Repeat to Do the Other One
continue to make the other ombre crystal cluster earring.
