How to Make PCB Using Marker
49,542
332
25
Published
Introduction: How to Make PCB Using Marker
About: HI! I am Junez Riyaz, currently doing Bachelor of Technology in the field of Electronics and Communication Engineering. I am much interested in inventing something new yet from my childhood. In my leisure ti...
A printed circuit board (PCB) mechanically supports and electrically connects electronic components using conductive tracks, pads and other features etched from copper sheets laminated onto a non-conductive substrate. Components – capacitors, resistors or active devices – are generally soldered on the PCB.
For more projects subscribe my youtube channel [ Subscribe ]
Visit my website for electronics projects and tutorials
Now I am going to instruct how to make a PCB using permanent marker.
Get Started..
Step 1: Components Required
Copper Clad [ Banggood ]
Ferric Chloride Powder [ ebay or amazon ]
Scrub
PCB drill [Banggood]
Permanent Marker [Banggood]
Step 2: Cleaning Copper Clad
Scrub the copper clad with scrubber until it becomes shines.
Draw the layout of the circuit on the copper clad .
Step 3: Etching the PCB
Add sufficient amount of ferric chloride powder to the water and stir it well to make ferric chloride solution for PCB etching.
Place the copper clad in the solution such that layout facing upward and wait for few minutes until etching is completed.
Step 4: Cleaning Marker Traces
After the etching is completed , place the PCB in water and clean it .
Clean the permanent marker traces by using nail polish remover or petrol.
Step 5: Drilling the PCB
Place the PCB on support for raising some height from the table surface, Use PCB hand drill or electrical pcb drill to make holes into the PCB.
Step 6: PCB Making Video
For more projects subscribe my youtube channel [Subscribe]
Feel free to comment.
My recent projects
1. How to make a LED Flashlight
2. Simple Audio Amplifier
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    25 Comments
    Thank you for a really great instructible that took me back to my youth (I was etching using Ferric Chloride in 1967...). I agree withthe comments about being very careful with ferric chloride, my hobby space was in the attic and one day i had seepage from my etching tank and turned a patch of the ceiling in the bedroom down-stairs brown! Oops! Relegated to the outside shed for etching from then onwards! Thanks for a great instructible - voted.
    Placing the PCB upside down in the etchant will create cleaner etched edges on the traces as well as decrease the etching time. A gentle rock of the container helps too. Occasionally check progress to prevent over etching.
    yes, i forgot to add in instructable
    If you cover blank areas with tape or big fat marker, you will use less ferric chloride. Connect them all and you'll have a nice ground plane for better shielding.
    I would not recommend using petrol (gasoline) as a solvent. There are so many solvents out there including isop. alcohol, paint thinner, xylol etc. that aren't as combustible as Gasoline.
    Yes , alcohol is one of the best.
    Ferric Chloride is nasty stuff AND it stains whatever it touches poop brown --- hands, shirts, jeans ...
    Much better etchant AND locally available is swimming pool muriatic acid from the home improvement store. Mix it 2 parts water to one part muriatic acid. Throw in about 5% by volume hydrogen peroxide if you want to etch faster.
    Alcohol is the recommended solvent for magic marker. Don't use the tequila afterwards in a margarita!!
    Can I use just a regular Sharpie for drawing out the template?
    I have used Sharpies to do this for years. Made my first board about 1976 using a sharpie and etching solution from Radio Shack (you know, that place where we used to be able to get parts and supplies before the days of cell phones and computers!!??!!). STILL make custom boards that way when I just need it for my own projects.
    You should test it first. Even some permanent markers get dissolved by the etching agent.
    Really a great and very helpful instructable. I am going to use this in all my projects from now on. Thanks!
    I used an ordinary Sharpie to make my first ever circuit board but, I
    used the Muriatic acid (pool supplies, Wal-Mart, etc) and hydrogen peroxide
    (any pharmacy, dollar store, etc) etchant. It worked fantasically well, much better than I
    expected. I was going to use Fritzing but actually ended up doing freehand pads and traces
    Excellent project. That is by far the simplest method I've seen. Is there a good open-source (free) program available for the circuit layouts? Well done.
    I use KiCad as it is triple platform,
    windoze, mac, and linux.
    Its free, but it has idiosyncrasies to get used to.
    Re. doing own etching,
    Seeed Studio Fusion PCB service is way cheap and very good.
    I highly recommend them.
    fritzing is one of the free resource tool
    I like this. I remember decades ago, we would do this with electrical tape to mark the traces.The edges would often be a little rough & irregular due to tape coming away at the edges. This is much neater. Though, like florinJ says sometimes the marker ink can be dissolved.
