This is the classic method that involves a bit of cooking on the stovetop - I prefer it because cooked playdough has a better texture than uncooked varieties. If you want the kids to be able to do it all themselves, try this uncooked playdough recipe.
Warning: Keep away from dogs and other pets. Playdough smells like people food but contains lots of salt, and a hungry dog can eat enough to cause a dangerous salt imbalance.
Remove these ads by
Signing UpStep 1: Ingredients
Basic ingredient ratios:
2 cups flour
2 cups warm water
1 cup salt
2 Tablespoons vegetable oil
1 Tablespoon cream of tartar (optional for improved elasticity)
food coloring (liquid, powder, or unsweetened drink mix)
scented oils
Visit Our Store »
Go Pro Today »
(or whatever the small thing is)
have great news!
This posting has won today's "I Made It" Challenge. For winning you will receive a 3 month pro membership!
Thanks for using instructables!
http://www.instructables.com/community/June-is-I-Made-It-Challenge-Month-Win-a-Pro-Mem/
I forgot oil :) but still outcome is excellent!
I made this last night with my 2.5yr old and he absolutely loves it!
The main problem I had is that the dough is still very grainy from the salt. I think next time I will dissolve the salt into the warm water before adding it to the rest of the dry ingredients.
Thanks!
Great website though!!!!
by the way what can use instead of cream of tartar or more precisely as a substitute of cream of tartar what can be used?
thank you for sharing
will this dry hard or do you have to bake it? and if so what temp do you put them in? do they crack once dry? and can you paint them?
I have a project that I need clay type of stuff for and if play doh works then I use it, but if not then is there a way to make clay that will dry and be hard but won't crack?
I can't afford the one they have here, it's expensive and it has to be fired to make it hard. Don't have that opinion where I live. So anything cheap that works just like the one that has to be fired would be great.
I made one batch, and then split it into 4 balls that were just under 1 cup each (I had 1 cup plastic containers for storage). Then, I used 1 package of unsweetened Koolaid for each ball. This seems like a lot, but they needed the whole package for the scent to really come through.
I use "lemonade" for yellow, which needed some yellow food coloring to bump up the color.
I used "blue raspberry" for blue, which only needed a little blue food coloring to make a nice bright blue.
I used "lime lemon" for green, and it really didn't need any food coloring because the mix alone made a nice bright lime green.
Then, I used "cherry" for red, and I would NOT recommend it. The cherry mix made the dough turn a sort of dull red, that even with food coloring stayed a dull brick-red sort of color. Next time I'll use strawberry for red.
We played with half of it, and wrapped hte other half in a pretty (plastic) container to give the neigher kid (1 yr. old). We also made another batch to give as a gift to some friends (3 kids) with whom we have a play day next week. What a great (an inexpensive!) gift and afternoon activity!
We scented and colored with ground cinnamon. MMMMMM!!!
I am also planning to make as a treat for my daughter's kindergarten class and give each kid their own for Valentine's day. She suggested red food coloring and cinnamon scent, but I am also thinking brown coloring and chocolate scent. What a treat!
Thanks for reminding me of this activity!
I was about to order some playdough online when I run into your recipe and decided to try it out. The recipe you have here is much easier and the playdough turned out great! I am saving myself some money!!Thanks!!!!!!
1. 2 cups wheat flour + 1 Tablespoon cream of tartar = Sieve them first
2. Add in 1 cup of fine salt
3. stir in the warm water + 2 tablespoon of vegetable oil with a fork until there are no more lumps. You can sieve the mixture again to remove lumps.
4. Pour into a non stick pan. Then stir over low heat. Keep on stirring. Within minutes, the dough will become playdough.
I did it this way, and it worked! For yellow i used, tumeric powder. For brown, i used cocoa powder. For green, i used pandanus leaves. And for blue, I used blue pea flower.
Hope this helps. :)
\Oatmeal Buddy Dough
2 cups smooth peanut butter
2 cups rolled oats
2 cups powdered milk
2/3 cups Honey
Optional-Rice Krispes, Coconut Sprinkles, Chocolate chips, Red hots, etc...
Mix ingredients until combined. Wash hands. Lay down wax paper. Let them play. Store in air-tight container.
Peanut-Buddy Play Dough (eatable)
3 1/2 cups Creamy Peanut Butter
4 cups powdered sugar
4 cups powdered milk
3 1/2 cups corn syrup
Mix ingredients by hand. Share. Can decorate with sprinkles, M&Ms etc.
Kool Playdough
3 cups Flour
1/2 cups salt
2 Koolaide packages
2 cups Boiling water
Mix dry ingredients together. Add boiling water. Knead on floured board can add flour by sprinkles until desired consistency. This playdough will last for a long time when stored right.
yummy playdough (eatable)
2 cups of honey
3 cups of peanut butter
3 packets powdered milk
Stir all ingredients together until smooth. Add more powdered milk if desired. Is sticky.
--------------------------------------------------------------------------------Cloud Playdough
1 cup water
1 1/2 cups vegetable oil
6 cups flour
Add a few drops of food coloring to water.
Combine water, oil and flour in a large bowl. Knead well.
Add more water if necessary in small amounts until the dough is soft and stretchy. Cloud dough should be used on a washable surface for it is very greasy.
Coffee Playdough
4 cups unsifted all purpose flour
1 cup salt
1/4 cup instant coffee
1 1/2 cups warm water
Dissolve the coffee in the warm water. In another bowl, mix the flour and the salt. Make a well and add 1 cup of the coffee water into it. Mix with a fork or with your hands until smoother. Add more coffee water as needed: dough should be smooth not sticky or crumbling. Store in air tight container. When your done making figures, bake in oven for 1 hour at 300 degrees or until hard. A coat or 2 of shellac keeps it well preserved for longer lasting gifts. Enjoy!
Fruit Playdough
2 cups flour
1 cup salt
4 tablespoons cream of tarter
2 cups boiling water
2 tablespoons of cooking oil
3 oz package sugar-free fruit flavored gelatin
Mix dry ingredients in pan. Add the water and oil. Stir over medium heat until mixture forms a ball. Pour onto a sheet of wax paper. Enjoy!
Salt Glitter
1/2 cup salt
6-7 drops food coloring
Add food color to salt adjusting to desired color shade. Cook in the microwave 1-2 minutes or you can also air dry your product. To keep soft store in air-tight container.
Frosting Playdough (eatable)
1 can Frosting Mix
1 1/2 cups powdered sugar
1 cup peanut butter(smooth)
Mix together until it reaches your wanted consistency. Enjoy!
1 cups flour
1 cups warm water
1/2 cup salt
1 Tablespoons vegetable oil
2Tablespoon cream of tartar (optional for improved elasticity)
we used blue food coloring.
Turned out great. You have to let it cook long enough. It looks like OMG this is going wrong but when it is like thick mash potatoes put on wax paper and let cool enough to knead and refrigerate. Daughter said it was awesome.
Unfortunately, I've lost my recipe - which is why I came online ot look for one - I will use this one but give the microwave a try!!
I remember bits overheating sometimes and you'd get dried out crispy bits but you just pick those off - still super easy and better than having to stir, you can also use a glass bowl so easier to clean than a pan :-)
The other two are perfect. I immediately washed the pan and it cleaned right up.
-- babs
2 cups flour
2 cups warm water
1 cup salt
or
20 cents
wal-mart
When some children love mixing the colors together( when their parents did not pay for it) is very costly.
Give it a try, you might find you like this better than store bought.
Assuming you can get a small amount of five colors out of one batch, this is comparable to a 2-4 dollar purchase, of play doh, on sale. Of course you get the little containers thrown in, although it's easier to get the stuff out of ziploc bags.
If you want more than just a little play doh, it can add up. Big gallon tubs of the stuff run like 16 dollars? These ingredients are much cheaper. If you don't have time to burn stirring, and hanging out by your stove, this may be the wrong website for you.
the initial output for these ingredients might be more, but to make an actual batch of this recipe would be half the cost AND you get to have fun in the kitchen with your kids. you could get 4 or 5 colours out of a single batch, increasing your savings several times over.
nemo
Please let me know.
fwiw, cream of tartar = κρεμόριο
ref: http://www.proz.com/kudoz/english_to_greek/food_dairy/1784704-cream_of_tartar.html
i also live in greece. did u find a substitute?
i think i'll just leave it out and see how it goes...have u tried it yet?
i speak a little greek but i'm working on more :)
Its a kitchen acid (in the same way that vinegar is an acid) that is also a type of salt. Its found in some candies, soda pop and baking powder. Its made from the sediment of wine making.
But you can always find it in the spice section of grocery stores and its always a white powder, not actually a cream.
And you can even use it to clean with.
*wishes we had a scratch-and-sniff option*
On the other hand, squishy hollow monsters may be super-scary!
I used neon food cooling and the play dough turned out great!
well anyway my recipe turned out great....heading out to colorr it ;) Thank you!
I'm not fond of it myself, but I bet you could buy some fragrance additive that will give you that same scent!
plz reply
THANKS =]
It helps make the dough more elastic, but you can certainly skip it.
my sister wanted mint though.
That makes it even more tempting to eat! I remember I used to munch on play-doh, and now with it being filled with kool-aid and vanilla, it seems like a decent snack!
I:D->---<
Play-doh turned out great!
Fantastic recipe. We made 3 batches for all the children in my preschool, they loved it! Finally a play doh recipe that’s worth keeping! (for those of you not successful... keep on stirring... it really works!)
but besides that it was good
http://www.after-school-care.com/Replies.aspx?Post=51&ReplyPage=1
After discussing with a more chemical-savvy friend, we think that the salt is doing the water absorbing part and makes the dough to be sticky after 1-2 days. Actually what is the salt doing in this recipe? Have someone tried to reduce the quantity of salt significantly?
Thanks to Strawberryholt for sending the alternative recipe, haven't try it though, since I haven't also look for the sand & alum...=p
http://www.flickr.com/photos/arnehendriks/2265068716/
Eric says your venison Asparagus is incredible. I've put it in the wish list for
http://www.instructables.com/community/Open_Source_Instructables_Restaurant/
Long answer: the salt is not purely necessary for making playdough- it acts as a preservative (keeps bacteria from growing if you want to store the playdough) and discourages children from eating it. While the rock salt will work perfectly for the first use, you don't want anyone eating it as it's not food-grade. If you plan to use the playdough for adults only it's OK to use the rock salt, but if kids will be anywhere near it you should only use food-grade salt.
1/2-1 cup of all purpose flour
1/2-1 cup of salt (not rock salt)
11/2 cup of water
I am going to put this up on Instructables later
Anyways I love the lil' scene that you made!
Right up there with drinking seawater. ;)
=D
thank you!
Ideas:
Add coloring at beginning. If you have to do multiple batches anyway, its fine. Otherwise, you'll only get one color.
Also: Adding a lot of extra salt, maybe an extra 1/4 cup. This will keep kids from eating the stuff.
http://www.demeterfragrance.com/Product.aspx?ProductID=1025
This is basically the same thing but with color. :)
Oh, and I should add that unlike play-doh, you can bake this stuff so if you really like what you've made then you can keep it that way permanently.
..or at least I don't think you can bake play-doh. But when I was searching I got distracted and found <a href="http://www.hasbro.com/media/default.cfm?page=release&release=478">this</a> o.0
Who would want to smell like Play-Doh?
I think making my own play doh is a very good idea :D
By the way ,if u are interested in creating something with play doh U can check my play doh maniacs group in flickr .It is a very funny group and there ll be competitions for our playdoh works and suprises for the winner ...
Check it out http://www.flickr.com/groups/338330@N24/
http://www.flickr.com/photos/8147018@N07/
http://www.amazon.com/exec/obidos/ASIN/B000EULZRS/yahoo-toys01e-20/ref=nosim
T = ???
