3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Make Playdough (Play-doh)
Step 2Mix and heat
Mix and heat
Mix all of the ingredients together, and stir over low heat. The dough will begin to thicken until it resembles mashed potatoes.
When the dough pulls away from the sides and clumps in the center, as shown below, remove the pan from heat and allow the dough to cool enough to handle.
IMPORTANT NOTE: if your playdough is still sticky, you simply need to cook it longer!
Keep stirring and cooking until the dough is dry and feels like playdough.
I've gotten many comments asking about sticky dough, so please just keep cooking a bit longer and it will work!
28 comments
Mar 22, 2012. 6:08 AMslipz says:
instead of warming it on the stove i used the microwave for about 3 mins butr check in between.....took less the time. :) turned out great and i substituted drink mix and food colouring for about half a pack of jello.....
Jan 7, 2012. 8:17 AMpntknanny says:
For the scent I added ground cinnamon, it smells awesome and adds a brown coloring.
Mar 8, 2012. 9:41 PMRayven666 says:
adding grounded cinnamon is a great idea i love cinnamon xD
Nov 27, 2011. 7:07 PMpossom pie says:
I have noticed that most recipes call for veg. oil and regular sal, what are the benefits for sea salt and canola oil? thanks
Dec 2, 2011. 5:57 PMdhooves says:
They'll also probably work but, Veg. oil and Regular salt is recomended.
Nov 27, 2011. 7:05 PMpossom pie says:
when do you add the scent and is the bottle ones you can get at crafts stores that are used for candles.
Oct 17, 2011. 2:50 PMdlynn4 says:
I have tried cooking it longer but the dough is still sticky......how can I fix it? I am actually in the process of trying to cook it again at this very moment
Nov 27, 2011. 7:33 AMawong17 says:
1. 2 cups wheat flour + 1 Tablespoon cream of tartar = Sieve them first
2. Add in 1 cup of fine salt
3. stir in the warm water + 2 tablespoon of vegetable oil with a fork until there are no more lumps. You can sieve the mixture again to remove lumps.
4. Pour into a non stick pan. Then stir over low heat. Keep on stirring. Within minutes, the dough will become playdough.
I did it this way, and it worked! For yellow i used, tumeric powder. For brown, i used cocoa powder. For green, i used pandanus leaves. And for blue, I used blue pea flower.
Hope this helps. :)
Oct 24, 2011. 10:12 PMmrussell101 says:
I had the exact same problem - spent hours waiting for the concoction to thicken. But today I discovered that the dry and wet ingredients need to be mixed separately and then combined. That made all the difference. It literally took me about 10 minutes, from start-to-finish, to make play dough.
Oct 25, 2011. 12:47 PMmrussell101 says:
I discovered one more thing today -- the water needs to be HOT!
Oct 28, 2011. 11:02 AMkatie1212 says:
do you need the creamof taaral
Dec 27, 2009. 4:15 PMkrazymonkey5454 says:
does it ruin the pot?
Jul 9, 2011. 9:29 PMkadams10 says:
my mum (this acc) says she did this long ago and it CLEANED the pot
Jun 8, 2011. 12:18 PMSpidamonkey610 says:
YES! you have to wash out the pot with hot water, and dish soap imediatly afterwards or else it does ruin the pot.
Apr 25, 2011. 10:40 AMspideee says:
yes
Dec 27, 2009. 6:06 PMsgsidekick says:
All ingreds are regular "food" ingredients.  At worst, you'll have to soak the pan for a bit in water and soap, so you'll be okay.  I wouldn't use a teflon pan or anything, since you may end up doing a bit of scraping if you let it set up on the pan *lol*.  I've made this before, and had no problems.
Apr 5, 2011. 3:49 AMarghhh says:
i made it and it wrecked my pan but my friend did it and it was fine
Apr 25, 2011. 10:43 AMspideee says:
mine too kid nice name arghhh
Jan 25, 2008. 11:08 AMsgreg says:
I tried this recipe without the tartar and it worked great! I saw a comment about scented playdough and I wanted to add that you can also use a packet of koolaid. It smells great and adds colour too!
Apr 25, 2011. 10:42 AMspideee says:
your welcome kid
May 22, 2009. 6:51 PMsammydog123 says:
cool
Mar 13, 2010. 10:16 AMbob the slob says:
we used this to make a exploding baking soda volcano....... it started to peel off the base. we took it off and used papper mach'e .( or how ever you spell it.) but any ways, we just use it to make screaming guys
wat up im new here tell me about this thing
Nov 30, 2010. 6:10 AMrogerrabbit321 says:
Does it dry quickly? or does it take like 2 days to harden? or will it just stay soft forever?
Oct 23, 2010. 12:03 AMjojo289 says:
My play dough turned out very sticky! I did what you said and cooked it alot longer but it got worse. i didnt use the cream of tarter, would that be the problem?
Feb 25, 2010. 2:57 PMapples22 says:
how long does it take?
Mar 21, 2010. 6:00 PMangie420 says:
only about 10 min all together and its really simple and doesn't get to hot- i recommend just a lil above low and it works great- i used canola oil and that seemed to work awesome! have fun!
Oct 7, 2009. 5:26 PMwixx says:
 i have tried making dis once and it came out good but den these boys ruined it and mixed the 2 play-doughs together and it was ruined
but besides that it was good
Jul 19, 2009. 2:07 PMhypersaiyan 7 says:
call me crazy but i LOVE that smell _
Jul 14, 2009. 3:18 AMThEbLoB! says:
I just looooove playdough so much that i just had to make a huge blob of it today! Thanks 4 your advice on the scented playdough. I'm sure it will make my playdough smell better than the salty, floury smell of it's original oudor. By the way, did you know that playdough was originally made 4 cleaning wallpaper??? ByE ByE!!!!
i treid this and got it wrong
Oct 7, 2007. 6:31 AMmatfu says:
Hi i was trying this activite and it just dousint seem to clump. Ive sterd it for more then 5 minutes could you help me here a bit thanks
Jun 26, 2007. 1:06 PMaligotskind says:
I saw one receipe it did not call for cooking. Can I just knead it without cooking...it is going to be a project for 3-year-old kids.
Sep 23, 2007. 5:06 PMsarahteacher says:
It does need cooking, but with an adult to add the boling water, this could work with a small group of 3-year olds. I made it with my 2 1/2 year old cousin last month, and it turned out well. Have them use wooden spoons and just keep stirring until it is cool enough to touch. It may be a bit too hard for them to stir alone though. Or make it your self and let them add the colour.
Sep 18, 2007. 10:38 AMwishbone says:
This one needs to be cooked. It's a horrible mess that can't be kneaded when first mixed but don't worry. It doesn't take much more than five minutes on the heat.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
413
Author:canida
I've been posting Instructables since the site's inception, and now run Community and Marketing. Follow me for food and more!
