How to Make Polymer Clay Beads
I love to make rather large polymer clay beads but the bigger the bead, the heavier the weight, which is no good for jewelry. I decided using a wood "filler" bead might help cut down the weight. Turns out it did and it also cut down my expenses b/c I wasn't using nearly as much clay! And that translated to selling the beads at a better price as well! Everyone wins! :D
Here's how I make inexpensive and light-weight polymer beads...
Step 1What you'll need.
What you\
-Pre-made Cane
-Tissue Blade
-Knitting Needle or Exacto-Knife or Stylus
-Wax Paper
-Liquid Polymer Clay (preferable)
-Wood Beads (size is up to you)
If you don't have a "pre-made cane", look for an instructable on "how to make a polymer clay cane". I'll probably have one out in a couple of hours. ;)
36 comments
Jul 11, 2011. 1:46 PMmaddymooskie says:
where did you get your pre made cane?
Jul 12, 2011. 5:49 AMmaddymooskie says:
how much do you pay for a cane of pre made cane
Oct 26, 2010. 1:42 AMWeaveKiller says:
You can bake the beads on a nice little "nest" of Polyfill. (It won't melt.)
Jun 21, 2011. 6:31 PMNaturalCrafter says:
Do you mean the same poly fill used for quilts and pillows or something else. That seems too easy.
Jul 12, 2011. 7:53 PMpopnicute says:
yes, it should be the same polyfill for bedding stuff. i bought the thick sheet ones and cut to fit my oven. it helps baking things that are not beads. it helps to keep your creations' shape really well. polyfill doesn't leave any marks on the baked clay.
Jun 21, 2011. 6:33 PMNaturalCrafter says:
Thanks about the beads..I just had to see what other things you are making. Fun stuff!
Jan 6, 2011. 8:36 AMBrutalMastodon says:
Have you tried using 6mm airsoft bbs for small beads? you can buy like 5000 for $10 or so, depending where you look.
Nov 9, 2009. 6:39 AMcraftymama11 says:
HI, IM NEW AT THE CLAY BEADING THING I HAVE A QUESTION.... HOW STRONG IS POLYMER CLAY AND CAN IT GET WET?
Mar 21, 2010. 1:35 PMSweet2Spicy says:
Polymer clay is not a mixture of "clay and polymer".
Polymer clay is made up of fine particles of polyvinyl chloride (PVC) suspended in plasticizer.  It is a completely synthetic compound.
Mar 21, 2010. 1:49 PMSweet2Spicy says:
Unfortunately your information in Step 7 above about the baking temperature for polymer clay is not correct.
You state, "Most polymer clays bake for 10 mins at around 200 degrees" ....
There is NO major brand of polymer clay that bakes at a 200 degree temperature.  This is far TOO LOW and will result in a weak and brittle product that breaks easily.
When polymer clay is baked at the proper temperature (normally between 250 to 300 degrees depending on brand) you get a strong, long-lasting product.
You are correct however in directing folks to read the instructions on the clay package.
Mar 23, 2010. 9:28 AMSweet2Spicy says:
I've never head of clay that bakes at only 210 degrees - that's way too low to bake out all the plasticizer and give a hard, strong product.
Here are the correct baking times for the top brands of polymer clay:
PREMO = 275 degree (for 30 mins each 1/4" of thickness - i.e. 1/2" thick equals 1 hour)
FIMO = 265 degrees
SCULPEY = 275 degrees
KATO = 300 degrees
Hope this helps.
Take care and happy claying.
Apr 12, 2011. 11:33 AMsassy111 says:
Everytime I cook my polymer clay for this long by beads have a tendency to burn. I have to cook my beads at 265 for 15 minutes no longer. They start turning brown
Apr 12, 2011. 8:00 PMSweet2Spicy says:
Are you cooking them in a small toaster oven? ... close to the heating elements?
Clay does not burn at 265 degrees unless you've got it right by the heating element. If you "tent" the clay with aluminum foil, this may help.
It sounds like you are doing something unusual here ... 265 is a very safe temperature even if you bake for 40 minutes (like I always do).
Mar 15, 2010. 8:55 AMLettucehead says:
 Yes! I have been trying to find instructions on these FOREVER!!! Yay!!!
Jan 2, 2010. 12:51 PMbeadydani says:
Very carefully explained tut, better than all the ones I have come across. I like the way you explain every step and why it is important to get it right.
I may give it another (had two failed attempts) try at some point but right now I am so busy with other aspects of jewellery making.
Thanks for sharing.
Dec 9, 2009. 10:08 AMlotusduck says:
 I have also heard that you can roll up dissolving starch packing peanuts to make a completely hollow bead, or a nearly hollow bead with a little something to roll around in there.
Nov 19, 2009. 4:55 AMKalaus says:
An even better alternative to wood beads is kitchen foil -- cut or tear it into approximately equal pieces, crumple and roll tightly into balls. Practice to see what size works better for you. Don't forget to make holes (use a needle or a toothpick) before they are covered with clay -- poking a hole through tightly rolled foil is not as easy as it may seem, you will need to hold it very firmly between your fingers.
Oct 18, 2009. 8:21 PMbassclarinet23 says:
Could you roll your own little ball and poke a hole through it, then bake it?
Oct 27, 2009. 12:53 PMbassclarinet23 says:
Okay. They're very professional looking.
Mar 30, 2009. 8:29 PMsuzettefsy says:
THANKS SO MUCH FOR THIS DEMO, I'VE REALLY LEARNED A LOT FROM THIS =)
Mar 26, 2009. 4:58 AMKJS says:
Looks nice :) Since the liquid polymer clay is only preferable, does that mean that it will work without it?
Mar 27, 2009. 1:44 AMKJS says:
Okay, thanks :) I'll try that.
Mar 26, 2009. 11:56 PMBard says:
Have you ever attempted to clear coat one of these things to see how it turns out?
Mar 25, 2009. 6:07 PMChrysN says:
Wow, those look neat!
Mar 25, 2009. 4:33 PMfwjs28 says:
oooooo...pretty!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
72
Author:thickneckarts(reondadomino)
I dig making hemp jewelry and upcycling would-be tossed items. I also run a free website that maps businesses that offer "free tire air" to the public. http://freetireair.com is the URL. Check it out...
more »
