How to Make Project Test Dividers
1,262
Posted in WorkshopOrganizing
Introduction: How to Make Project Test Dividers
Get supplies to started
28 pieces of cardboard (9.5 inches wide and 19.5 inches tall)
3  3 piece cardboard holder (3 mm thick)
7 1 piece cardboard holder (3 mm thick)
Ruler (for accurate measurements)
Step 1: Pre-Construction
To start the project make sure that all your 3 and 1 pieces of your cardboard holders are cut down the middle so that there is a little slit where later the cardboard will later slide through.
(take picture of all 8 cardboard holder pieces, take picture of slit)
Step 2: Organization
First we started off with our 28 cut cardboard pieces.
Step 3: Label & Construct
Then we paired the cardboard by two's so there was 14 pieces left.
Step 4: Merging Items/pieces
After that we taped the cardboard all around the perimeter taping it to the opposite side of the other card board.
Step 5: Adding Iems/Pieces
When we finished doing this for every pair, we had a total of 14 cardboard pieces.
Step 6: Add More Pieces
Then taking the 14 cardboard pieces we taped them together so that the cardboard was 19.5 inches high, and was left with a total of 7 cardboard pieces left.
Step 7: Conclusion
Using the 7 pieces we sketched out an I type shape with the cardboard to work it out.
Step 8:
We connected the first row of cardboards together using a 3 piece connector. Then from that we placed an additional cardboard vertically down also connecting to that same 3 piece connector. We then added another 3 piece connector.
Step 9:
After this we had one cardboard sticking out of the I formation we had. Continuing the I formation we added another cardboard down with the last 3 piece connector sealing it.
Step 10:
Lastly we stuck the cardboard on both sides, and added the single pvc cardboard holders to the tops of the cardboard to keep them stable.
Step 11:
And then we tested to see if it worked fine.
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
